2007 Civic Si, going into gear but not moving [solved]
just replaced my clutch, once i was finally done with everything i took it out for a drive. before i exited my street the new clutch was grabbing then as i was letting it out it went past the grabbing point and went into neutral. it is now stuck in neutral (can shift without clutch, car is on) took off the transmission and thought it was my pilot bearing (it was destroyed) replaced it, put everything back together same issue. clutch is bled, haven’t found any leaks NEED HELP
FFD123
Aug 12, 2023 05:43 PM
Bonnie876
Sep 19, 2013 12:16 AM
sameer71992
Mar 12, 2013 05:40 PM
gini1215
Jun 10, 2010 06:17 AM
KenB
Sep 22, 2007 02:09 AM
