Trans removal
Trans removal
I have an 08 civic 1.8 auto w a bad trans. i got the replacement but am nervous about it. ive disconnected the CV axles, most of the visible plugs, drained the fluid and disconnected the lines connected to the block. i know im going to need to drop the subframe but not sure where to go from there. i havent been able to find much help on 8th gen auto trans removals. anything?
Re: Trans removal
Next time create your own thread instead of replying to some random unreated thread.
Try searching for a clutch replacement video/walkthrough. 90% of it will be the same.
Re: Trans removal
Online manual available for free.
http://civic.hondafitjazz.com/manual2.html
Link directly to transmission removal:
http://civic.hondafitjazz.com/A00/HT...000KAAT00.html
Just a warning. When you separate the transmission from the engine, there's a possibility that the torque converter will stick to the flexplate and separate from the transmission. This will dump transmission fluid all over the damn place. I've never pulled a transmission from one but this happened both times I removed the engine from an 8th gen.
fripperiffic
Dec 4, 2010 04:15 PM
hondachrisnc
May 13, 2006 11:20 PM
