Error code P2821 Civic 2013
Hello,
I have a 2013 Honda civic, A/T. I had to swap my gearbox about a month back and ever since I get the transmission error with code P2821. I have checked all the sensors and pressure switch, connectors and battery. Yet the problem insists. I get the error whenever the car is cold and has just started running. It goes into limp mode with D flashing. If I turn off the car and switch back on, the error goes away and everything is back to normal for some time then comes back. Once the engine is hot, the error doesn't come back. Can anyone please help.
Re: Error code P2821 Civic 2013
Did you swap solenoids/sensors from the old transmission onto the new one?
Third post in this thread shows you where the solenoid is. https://www.civicforums.com/forums/3...de-issues.html
