Whining Transmission at Low Speeds (<30kmph)
Old Oct 2, 2020
umeralikhan's Avatar
umeralikhan is an unknown quantity at this point
Question Whining Transmission at Low Speeds (<30kmph)
All,
Help needed. I have an 8th Gen Civic with 88000km on the odometer.
Car makes a low whining noise when accelerating from standstill. The noise is there till around 30-35kmph and then vanishes. I feel its there when the car is on lower (1st and 2nd) gears. the noise comes back when the car downshifts when decelerating in same speed range.
I isolated the issue to transmission since the noise immediately vanishes if i throw the car into Neutral while moving. At first i suspected the transmission fluid (since i bought the car recently) so i replaced the fluid with Honda ATF-DW1 (I replaced using the drain bolt, and the total fluid replaced was around 4L. I couldnt get the fluid out from the torque converter).
Can someone help me out on what could be the reason? Could it be low ATF level? or a faulty transmission pump?
I consulted a few mechanics who were reluctant on transmission rebuild/repair and insisted to just replace the transmission which i cannot afford.
Eager for help/opinions.
cfahamilton
Mar 27, 2021 05:06 PM
johncoby
Transmission
Sep 20, 2019 07:52 PM
lgn98868
Transmission
15
Feb 13, 2018 08:27 PM
philsil
Jun 15, 2006 06:40 PM
Konger
Sep 13, 2005 03:41 AM
