2006 Honda Civic need help will not go into gear while running
I have a 2006 Honda Civic it will not go into gear while it's running the master cylinder fluid level was empty so I suspected a leak replace the master and slave cylinder and the entire line no leaks now I bled it for about an hour and the car will not go into gear still. put a camera inside the tranny and it looks like the clutch fork and throwout bearing is pushing on the pressure plate don't know if it's enough to disengage the clutch or what's going on I could really use some help I can't afford to put a clutch in it right now was driving fine just one day it wouldn't go into gear
Re: 2006 Honda Civic need help will not go into gear while running
Slave cylinder is probably bad, these cars are a real pain to bleed
Captaintony
Feb 19, 2017 06:29 PM
Dcparker
Sep 12, 2014 10:41 PM
bullseye
Jul 21, 2004 03:05 AM
