2012 transmission. Issue
Old May 27, 2019
grgdotson's Avatar
grgdotson is an unknown quantity at this point
My daughter wrecked her 2012civic. The Transmission solenoid was bumped and was leaking. I replaced the shift solenoid with one off of eBay. I changed the fluid and now it won't shift into 2nd and 3rd unless you let off gas right before it shifts.Then it goes into gear smooth. Also if you shift down to low 1 it has a delay and shifts hard into each gear as you go up to drive. I hope it's just a bad decision in getting the part off ebay. Was going to get an one part next. Any recommendations? The car had no issues and has about 75,000 miles.
Old May 28, 2019
mac25's Avatar
Dr Krieger of Modification
Re: 2012 transmission. Issue
Replace with OEM for sure.
You might be able to find the part cheaper than through the dealer though.
-get the OEM part number and you should be able to find the right one. Probably a Denso branded part.
You can try Denso's parts lookup sight.
Or
A direct online Honda supplier
ocnwolf99
Jun 5, 2018 01:46 PM
shookonee
Jan 14, 2018 08:15 AM
NOStuner1998
Oct 6, 2017 08:33 PM
Addy Berry
Oct 1, 2017 04:20 PM
cruisers10
May 12, 2015 10:46 PM
