08 no crank and no indicater on dash for prndl [solved]
Old Jan 6, 2025
Nlach390's Avatar
Nlach390 is an unknown quantity at this point
So my nephew has an 08 civic lx I believe, 1.8, AT. He pulled into work, after work no crank. We just got hit with ice so I had it towed to my body shop today. First time seeing the can I put it in neutral for the tow truck and noticed there was no dot lights next to prndl on the dash. Not sure if it's the neutral safety switch or what. Of course I forgot to try to start it in neutral. But on other things his temp gauge all of sudden went dim. Any one help me out or dose the car need to running to have the lights next to which gear it's in?
thanks
Old Jan 6, 2025
Nlach390's Avatar
re: 08 no crank and no indicater on dash for prndl [solved]
I did also it did not indicate reverse or neutral
Old Jan 7, 2025
Nlach390's Avatar
Solved, hooking up a scan tool brought back communication, basically lost communication f-can. Ended up being broken ground from engine to body. Hope this helps someone
AsianSalt
Jun 29, 2021 10:56 PM
jonahbrown
Electrical
Jun 11, 2020 08:31 AM
David Byargeon
Apr 12, 2020 06:27 PM
ernest64xp
Engine start problems
Apr 4, 2019 05:35 PM
