rpm drops when a/c is switched on and automatic transmission gear put in Drive mode.
Old Jul 18, 2022
Aeroguy's Avatar
Aeroguy is an unknown quantity at this point
My 2008 civic rpm drops to 500 when I switched on the a/c and put my gear to drive mode together. if only a/c is on, gear in neutral,the rpm remains stable at 750-800rpm. This happens only during cold start. When the engine warms up approx 5mins after engine running then idle rpm become normal at 750rpm...Mechanic already cleaned the egr, cleaned throttle, fuel injector, adjusted piston valve clearance..same problem exist during cold start..what to do next?
19CivicSport
General 10th Gen
Jun 14, 2019 09:47 AM
danieljensen98
General 8th & 9th Gen
Mar 6, 2019 02:43 PM
j3ffo
Jul 31, 2012 09:09 AM
aznpride3000
South Cali
Jun 1, 2004 01:57 AM
redvtec04
Apr 23, 2004 12:27 PM
