help
Old May 28, 2004
aznpride3000's Avatar
aznpride3000 is an unknown quantity at this point
help
my car redlines @ 5000 rpm on parked gear and nuetral gear when its not moving.But when its like at 15 mph it redlines to 7000 rpm on neutral is there any way to make the car redline to 7000 when they car is not moving or in park gear?
Old May 28, 2004
MangoEX's Avatar
Just Be
MangoEX should not be trusted
Ehhh.. Why would you want to do that? It's called a fuel cutout -- it's put in place so you don't do 7k neutral drops.
Old May 28, 2004
so i could have a better take off
Old May 29, 2004
KaZeLL's Avatar
KaZeLL will become famous soon enough
nice jake up the engine for a faster jump....sounds like a winner to me...lol
Old May 29, 2004
Handsonme's Avatar
^^ What he said. ^^
Old May 29, 2004
Nodnero's Avatar
Im also guessing that you drive an auto yes???? If so, this is your reason why. The auto tranny cut in neutrel is 5k rpm.
Old May 29, 2004
7thGenerasianCivic's Avatar
Bad bad thing to do. Go sit in the corner Mr.!
Old May 29, 2004
xstrghstx2k1's Avatar
xstrghstx2k1 is an unknown quantity at this point
well it is a good way to destroy the tranny...
Old May 29, 2004
CivicHX01's Avatar
the fuel cutoff is there for a reason... and don't do neutral drops anymore..
Old May 29, 2004
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
LOL....
My 88 Camry V6 tranny was replaced at 140K, died again at 220.
Quoth my tranny guy:
"The life of an automatic transmission is inversely proportional to the size and weight of a driver's right foot!"
It might have been better if I knew about redline's ATF product then, but still... If you want to do power burnouts and drops, get a stick shift!! At least then you just have to get a clutch job instead of the whole tranny at $2000 +.
Old May 31, 2004
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Keep putting your auto tranny in D from 5000rpm's... let us know how many times it takes before it blows. I'm betting around 15-20 times...
Old Jun 1, 2004
Elite's Avatar
Elite is an unknown quantity at this point
Guys I believe its not a fuel cutoff. I think auto's have a rev limiter on the civics. I have an auto ecu and I have a manual tranny and mine does the same. It doesnt cut off the fuel it just has a rev limiter at 5k, and when your moving its differen't.
Old Jun 1, 2004
Elite's Avatar
If you want, buy a manual ecu, you wont have reverse lights though, hook it up, and reflash the ecu so it can work with your key and the immobilizer still works. You will have a check engine light. But I guarantee it will work. I got the ecu for 100 bucks btw, if you wanna buy it off of me, its for a 7thgencivic manual tranny.
