Blown 2010 honda civic swap with 2012 honda civic 1.8 issues !!!
Old May 17, 2022
rickyjohn22's Avatar
rickyjohn22 is an unknown quantity at this point
Hey guys I'm new .
So I have a 2010 honda civic 1.8l that the engine blown completely, I swapped it with the same model honda civic but a 2012 same engine 1.8l it was running.
After the engine and transmission was swapped into the 2010 chasis i noticed couple sensors didnt clip in so switched with the ones from the other engine no biggy. Also noticed the crankshaft sensor is located on the other side of the engine so I extended the wire checked the diagram and connected it.
I'm now having issues it won't start , it wants to. it'll crank and you smell fuel but it won't start. I did change out the fuel rail with injectors from the original engine because I thought maybe the wiring was different. which wasn't the case.. I need help . I have spark intermittent and fuel intermittent it doesn't seem strong .
Im at a loss i went as far as i know yow to go . if you can help i appreciate it .
Tiki82
Engine Swaps
Feb 14, 2018 08:44 PM
giantsfan923
Jul 26, 2011 01:34 PM
wrangler77
Jan 16, 2010 07:54 PM
trev0006
Jan 3, 2009 06:33 PM
