Engine temperature high warning
Old Dec 17, 2021
Goldie1980's Avatar
Goldie1980 is an unknown quantity at this point
Hello all,
I have a 2014 Civic 1.8 petrol and my temperature gauge keeps rising rapidly then fluctuating. It has even reached the engine temp high red line with the system warning.
This is normally when driving at low speed or idling and seems worse with heater air con on.
It is not losing coolant and oil is fine so I am at a loss as to what it could be. Could it be a sensor?
Many thabks in advance.
Old Dec 17, 2021
FRSam's Avatar
Click Here
Re: Engine temperature high warning
It sounds like your thermostat may be stuck open. Does it read low on the highway?
Old Dec 17, 2021
Colin42's Avatar
Have you checked the coolant level?
Old Dec 18, 2021
Goldie1980's Avatar
Hi thanks for the reply, yes fine on highway just at low speeds and idling
Old Dec 18, 2021
Goldie1980's Avatar
hi Colin
Yes the coolant seems fine. Not budged at all
Old Dec 18, 2021
Colin42's Avatar
Check the thermostat as stated earlier, and check that the fans are working properly
Old Dec 18, 2021
carry a temperature gauge for the next time it "overheats" so you can check if it is really overheating? might be too late by then, though
Murph67
Dec 29, 2017 09:49 PM
Walter_1980
Aug 17, 2016 08:56 PM
DEZZIE41
Nov 17, 2012 10:24 AM
jdmek420
Jul 14, 2012 02:39 PM
MrDobin
Jan 3, 2012 06:31 AM
