07 honda civic crank no start
Old Jul 28, 2021
Johnnyblaze757's Avatar
Johnnyblaze757 is an unknown quantity at this point
I have a 2007 Honda Civic with 1.8 liter in it. Used the car night before was a little sluggish but seem to clear out .go out to go to work next morning started and shut right off. Did some testing later that day and would run off carb cleaner so thought was fuel pump. Replaced pump and still does same thing. Any suggestions?
Old Aug 1, 2021
Wankenstein's Avatar
Re: 07 honda civic crank no start
Might be flooded? Try starting with the gas pedal fully depressed. This shuts off injectors and allows maximum amount of air into the cylinders.
For future reference test as much as possible before replacing parts. A fuel pressure test would have revealed if the fuel pump is working correctly or not.
Combat Cow
May 8, 2022 06:50 PM
cjtorres
Mar 11, 2019 09:02 AM
Ted-04
Feb 5, 2019 01:52 PM
boostem2
Dec 4, 2011 05:56 PM
walltumbla
May 27, 2011 11:30 PM
