Lower torque Motor mount help please!!!!
Old Jun 20, 2021
Ancv43's Avatar
07 Honda Civic Ex
Ancv43 is an unknown quantity at this point
Hello, I need help please on how to pull the long 17mm rusted bolt,, ,, if you look at the pictures the top nut broke loose ,, can’t believe Honda only gave that top nut 3 tack welds.. I broke it with a breaker bar and now the nut is out but the bolt is seized in mount hole ,, it spins because the center rubber of the mount is broke and the bolt is seized stuck in the mounts metal sleeve… Anyone please give me an idea on how to free the bolt. I can’t bang it out from the top because of no room to even get a hammer or punch.. Has this happened to anyone on here? Please someone give me a idea.. thanks in advance
Old Jun 20, 2021
Re: Lower torque Motor mount help please!!!!
prybar
Old Jun 20, 2021
Colin42's Avatar
Air chisel
Old Jun 20, 2021
FRSam's Avatar
Click Here
Plasma cutter
*as every answer proceeds to get more extreme
Old Jun 20, 2021
Ancv43's Avatar
07 Honda Civic Ex
Originally Posted by Colin42
Air chisel
I don’t own an air chisel. I tryed hitting around the mounts with a hammer and chisel but no success
Old Jun 20, 2021
Ancv43's Avatar
07 Honda Civic Ex
Originally Posted by Chezboat24
Plasma cutter
I wish I owed a plasma cutter.. it would of been done by now..
Old Jun 21, 2021
BrotatoChip's Avatar
Super Moderator
I'd be surprised if you get that bolt out in one piece. You will likely have to cut off the end and the head, then replace it when installing the new brace.
Old Jun 21, 2021
Ancv43's Avatar
07 Honda Civic Ex
Hello ,, by any chance do you know the part number for this bolt? The main long lower torque strut bolt size?? Thanks in advance
Old Jun 22, 2021
Super Moderator
https://www.civicforums.com/forums/2...retailers.html
Old Jun 25, 2021
Ancv43's Avatar
07 Honda Civic Ex
What Tap to chase nut threads
On my 07 Honda Civic EX I am replacing the driver side lower control arm, I had to cut out the 14x94 bolt because the bolt was seized in the control arm bushing hole.. I did some damage to the threads on the nut that welded to the cars frame where the 14x94 bolt screws in.. If anyone here knows what Tap do I need to clean and chase the threads on that nut where the 14x94 bolt screws in… thanks in advance…
Old Jun 26, 2021
Ancv43's Avatar
07 Honda Civic Ex
Re: What Tap to chase nut threads
Nevermind ,, I found it… it’s a Tap 9/16-18
Old Jun 26, 2021
Pretty sure it'll be an m14-1.5, but if it still threads without actually changing the thread pitch/removing too much material, I guess a 9/16-18 will work. Everything on these cars are metric
Old Jun 26, 2021
not a DIY article, rather a question, so merged the tap thread into your own thread of motor mount. (Will make clear what you are trying to tap anyway)
DIY section is for members posting how they solved the problem. Questions do not belong there.
Makes harder to find good articles later.
Old Nov 1, 2024
Pbreakall's Avatar
Pbreakall is an unknown quantity at this point
Someone please help. Same thing just happened. The nut on top broke off sub frame. The bolt spins but I think it’s rusted into the metal ring of the mount. It just spins and spins but doesn’t come out.
Old Nov 2, 2024
Colin42's Avatar
Is the nut inside the subframe or is it accessible?
Old Nov 2, 2024
Pbreakall's Avatar
I was able to unthread it off the top of the bolt head, so I have it
Old Nov 3, 2024
Colin42's Avatar
Ok if the bolt wont come out just get a new bolt and mount
Old Nov 3, 2024
Pbreakall's Avatar
The bolt can't be removed because it's stuck inside the mount
Old Nov 4, 2024
Colin42's Avatar
Cut the bolt and mount as needed to get it out of the car
Old Nov 4, 2024
Super Moderator
If you read the thread you replied to, you would see previous recommendations for the OP.
Ancv43
Jun 18, 2021 07:59 AM
civicenthusiast
Feb 9, 2021 07:06 AM
pcpro215
Nov 2, 2015 08:09 PM
cgriffin51
Oct 31, 2015 03:43 PM
mrohitredd
Jul 21, 2015 09:26 AM
