Flashing check engine light
Old Feb 4, 2021
EarleD's Avatar
EarleD is an unknown quantity at this point
2011 civic lx. 208000 miles
Replaced the plugs about a year ago with the proper plugs. Asked here
coils are original
was Driving home from work and the car shudders and CEL was flashing. I pulled over and **** car off
waited about 5 minutes. Googling this.
started car again and light cel of off. Car is driving fine. Went to read any codes and there were none. I thought this was weird.
any thoughts?
Old Feb 4, 2021
FRSam's Avatar
Click Here
Re: Flashing check engine light
Flashing light indicates a misfire.
Old Feb 4, 2021
EarleD's Avatar
That’s what I found. But no codes
Old Feb 4, 2021
EarleD's Avatar
Took it to a mechanic I trust. He said if it went off and no code. It could be a glitch.
if it comes back try to get a code. Reader is in my car now.
-time chain jumping he said it wouldn’t clear.
-possible bad coil. Try to get a code to determine which coil. Then swap two to see if it follows a coil
keep driving it. If it comes back we can go from there
Old Feb 4, 2021
get a dongle to transmit OBDII from amazon
get torque pro for your smartphone.
turn log data
you should have everything logged as you drive
Old Feb 4, 2021
specifically, catalyst damaging misfire condition.
if it's running fine now,you may not necessarily have the CEL illuminated, but misfire codes should be stored. Unless you actually got it scanned and zero codes -- stored or otherwise -- don't exist, then that's just weird.
Old Feb 5, 2021
EarleD's Avatar
no codes pending or stored.
Old Feb 5, 2021
EarleD's Avatar
turn log data
can you recommend one. I’ll grab it asap
Old Feb 5, 2021
EarleD's Avatar
Drove to work this am, 35 miles of highway. No issues
Old Feb 5, 2021
EarleD's Avatar
FOXWELL NT301 OBD2 Scanner Professional Mechanic OBDII Diagnostic Code Reader Tool for Check Engine Light
Amazon Amazon
This is my code reader. It should do live data. I Think.
Old Feb 5, 2021
too many of them.
WIFI models did mess up my phone reception, so i would say bluetooth model is better.
choose something in the mid-range to low on price range (too cheap is dangerous, meant as likely to live longer, too expensive is likely rip-off)
Old Feb 5, 2021
EarleD's Avatar
My reader can show live info. It worked on my way home. Have no idea what I’m looking at though. Lots of numbers changing constantly
thanks for your help
Old Feb 8, 2021
EarleD's Avatar
Ok. It’s been about 200 miles and nothing. I figure a maybe a flakey coil.
should I change them? They are original. 208000 miles. Car runs great.
Old Feb 8, 2021
my coils have been there since 2002, not sure honda coils actually gets bad so often.
just wait for next or keep an eye to anything (like MPG going down)
Old Feb 22, 2021
EarleD's Avatar
Been a couple of weeks. No issues at all. 🤷‍♂️
Old Feb 22, 2021
Colin42's Avatar
No news is good news
ReD2k1
20
Jul 17, 2023 06:46 AM
ChicagoDriver
Feb 8, 2021 07:49 AM
greencivic98
May 13, 2018 08:16 AM
Adam925
Feb 25, 2016 11:39 PM
vozo112
Jan 10, 2014 06:05 PM
