08 Not starting after battery replacement
Old Feb 11, 2020
Dano84's Avatar
Dano84 is an unknown quantity at this point
Hi, I recently purchased and 08 civic. I drove it for about 10 days with no problems. I went to to start it one cold morning after not driving it for a few days and it cranked but wouldn't turn over. I hopped in my other car and didn't come back to the civic for a week. This time it was in the afternoon on a sunny day so cold wasn't a factor and I got the same result, decent crank but no turnover. The battery was 4 years old with a little corrosion so I decided to just go buy a new one. After installing the new battery I was hoping it'd fire right up. No luck. It was actually cranking less than the old battery and after a few tries, now not cranking at all. Power seems to be getting the the vehicle just fine as all electrical inside works just fine. Not sure if I have a starter issue? Is it possible I messed up the terminals when I cleaned them with a metal file (fairly lightly) and I just need to replace those?
Old Feb 12, 2020
BrotatoChip's Avatar
Super Moderator
Re: 08 Not starting after battery replacement
Crank and turn over mean the same thing, you're contradicting yourself. So you're saying it's cranking but just won't start? If you turn the key to the ignition position do you hear the fuel pump run for a few seconds?
Old Feb 12, 2020
Dano84's Avatar
Apologies, I always assumed turn over meant the car actually starting. I can hear the fuel pump run for a few seconds when turning the key. I went out this morning and tried to start and was getting a very feint crank, barely any.
Old Feb 12, 2020
Super Moderator
Sounds like the battery is now dead from being cranked for so long, you will likely need to charge it before testing some more.
Try cranking with the accelerator pedal all the way to the floor.
Old Feb 12, 2020
Colin42's Avatar
could be the new battery was bad from the store, i've had it happen
Old Feb 12, 2020
Dano84's Avatar
I am wondering if the new battery might be bad since I went from a decent crank to almost nothing after I put the new battery in but have never had an issue with a new battery before. I've had the old battery on a charger for 14 hours and going to put it back in tomorrow and see what it does. I did test both batteries with a multimeter, and after a short time on the charger the old one was putting out more than the new one.
ScruffyLG
Jan 20, 2018 05:05 PM
akaali8461
46
Apr 11, 2015 05:10 PM
kellieanne
Electrical
Jan 25, 2011 01:00 AM
goliath
Jul 20, 2010 06:33 PM
riceboi
Dec 4, 2002 05:01 PM
