Need help with throttle body hose routing
Old Dec 13, 2019
rayjones421's Avatar
rayjones421 is an unknown quantity at this point
Hello I have a 2010 Honda Civic si that I replaced the original engine with a k20 engine and when I was putting the intake and throttle body on I forgot how the hoses connect to it I can’t find how to route it right can anyone help me with my problem
Their are three places where hoses need to go and I don’t l know what goes where like the one on the top of the throttle body and the one on the bottom of the throttle body and on the metal hose with the end exposed
Old Dec 14, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Need help with throttle body hose routing
I can only speak about general TB setup, as I do not know that specific vehicle.
-There is usually two coolant ports, about a 1/4" diameter. Most of them are open flow to the sensor, so direction shouldn't matter. (You can blow into one end of the set to find the other.
-The rest of the ports are vacuum ports. All of them end up drawing vacuum from the same place so it doesn't matter how they are setup.
-it's ok if you end up with too many, or two few vacuum ports due to engine configuration. If too many just cap off the extras; too few, buy a "T" connector.
Old Dec 14, 2019
That big one front and center looks like a fuel supply line to a fuel rail, but I'm not quite familiar with the layout of a K20Z3
Old Dec 16, 2019
BrotatoChip's Avatar
Super Moderator
Let me try to explain where everything goes.
The two small hoses at the bottom are coolant lines for the IACV. The one you have connected is on the wrong one. Move the hose up to one above it. The one on the bottom goes to the right off the side of your picture. It connects to the big, metal main coolant line.
-The bigger one next to the throttle body inlet is the crankcase breather. It should connect to the intake somewhere, not sure exactly where.
-The bigger one on top of the intake manifold is a vacuum line, it should look like this:
kbook
Feb 16, 2011 01:30 PM
H3RKID
Nov 12, 2010 11:41 AM
Storm897
Nov 18, 2009 02:31 PM
brian02
Oct 29, 2009 07:38 PM
opto_isolator
Engine Swaps
Dec 23, 2003 09:40 PM
