2006 civic si exaust noise only in certain gears at certain speed
Hello everyone im new to this forum amd could reall use some help. Im the new ownerof a 2006 honda civic si the car ran great the first week of having it but about 2 weeks ago ot started makimg a noise that sounds like an exaust leak to me coming from under driver floor board or possible behindtje dash where the manifold would be the noise only happens once i get into 4th gear and continues threw 5th and 6th but if i push the clutch in and rev the motir while at the speeds of 55 or 60 in these gears the noise goes away also i can re create the noise while sitting at idleor with the car on jackstands amd wjeels off the ground shifting threw gears ive tried a mew exaust manifold ive tried new catalytic convortor and still the spumd is there i am mechanically inclined so if anyone has ideas please help me its driving me crazy. Thanks in advance
Re: 2006 civic si exaust noise only in certain gears at certain speed
Ezone thank you for your response all help and suggestions is greatly appreciated. I'm pretty sure it's not exist drone because the sound wasn't there when I first got the car and just randomly started unless that is something that can just randomly start I will give the motor mounts a good looking over to see if there is any issues because that could be possible because here lately when I back up and go forward I get a little bit of a shake but it only happens when I back up first. To me this noise sounds just like exhaust leaks I've heard in past but only this one makes a kinda sputtering noise with it like you know how kids blow aor out between there lips and makes a sputtering noise like that so please keep suggestions coming I've looked everywhere for a leak and can't find it. Thanks
Nobody else has any suggestions or have expericed something simular? Ive replace the hole exaust nothing changed i replaced motor mounts nothing changed please any suggestions is appreciated
dupontracer248
Feb 9, 2015 08:43 AM
p-of-s civic
Nov 26, 2011 06:31 PM
mkokotovich
Aug 26, 2011 07:16 PM
speedracersong
15
Sep 26, 2007 12:07 PM
