Honda Civic vibrating noise when moving...need help!
Old Nov 25, 2011
p-of-s civic's Avatar
p-of-s civic is an unknown quantity at this point
hey everyone,
i have a manual 98 Honda Civic EX. recently it has started to make a vibrating noise whenever it is moving. The frequency is proportional to the speed of the car. when i turn the noise becomes louder. At first i thought i thought it might be a wheel bearing issue, but i have read that the noise is described more as a humming sound rather than the pronounced thumbs that are occurring. The noise is not affected by braking and continues when the car is put into neutral. I cant afford a mechanic so any help would be greatly appreciated.
Old Nov 26, 2011
Rahway09's Avatar
Rahway09 is an unknown quantity at this point
Re: Honda Civic vibrating noise when moving...need help!
does it happen when its raining? like i have an 02 civic and it happens to me but its only when its raining because there is a flap under the car that is loose. mine has the vibrating noise in the passenger seat
Old Nov 26, 2011
Shift-E's Avatar
That Dude with the Questions
Did you change the rims recently? Or hit anything? I got a vibrating sound from a bent rim after i hit a curb with it.
Old Nov 26, 2011
lowlife9's Avatar
check the motor mounts. also check your exhaust hangers under the car.
Old Nov 26, 2011
Rahway09 it happens regardless of the weather. and yeah, the problem started after i hit a curb in the rain, im pretty sure thats what did the damage. i took the wheel off today and even spinning it by hand i could hear a thumbing noise. im having trouble telling if its coming from the hub or further up the axle.
jessicakaybby
Apr 20, 2015 12:11 PM
