Loose belt effect timing?
my 2007 civic with 170,000 miles has a timing chain and recently developed symptoms of a loose chain. It would run for a few seconds and then quit. The problem started soon after I heard a noise like a belt letting go. My mechanic found the serpentine belt tensioner was bad and replaced the belt and tensioner and says it ready to go. From everything I know (which admittingly isn't much) is the engine should be able to run without the belt but I wouldn't have a water pump, alternator or power steering. My question is can the serpentine belt cause the engine timing to be off? The only way I can see that happening is the belt somehow keeps a loose timing belt tensioned, right? I'm going to pick it up today and don't want to get half way home and be stranded along the side of the road.
thanks
thanks
Re: Loose belt effect timing?
there's a tensioner for the chain as well...
why are you picking up a car that still isn't fixed?
I would suspect other things before a chain issue based on your description.
Mechanic has belt and tensioner replaced now, does the engine run correctly-- or not?
Accurate diagnosis is valuable. Guesses are not.
If the serpentine belt came off, you know the water pump was not operating. So....how long did you keep driving without that belt?
Engine overheat could happen in just a minute if the water pump is not working.
The belt never came off. The mechanic said the tensioner bolt had worked itself loose and was rubbing on the water pump.
I picked the car up because my mechanic said that after replacing the bolt, tensioner and belt the car was running fine. I have to say it is. I drove it home (about 30 miles) and it is running normal. I just thought it was strange the car would quit and the start right up for a couple secs and then quit again. I guess that's why I'm a backyard mechanic and pay the real mechanic to diagnose and fix the actual problem
LoganH91
Mar 27, 2015 12:35 PM
trez777
May 8, 2013 03:33 PM
Tennessee Mike
Sep 28, 2010 07:32 PM
grey2k11
Aug 21, 2008 02:28 AM
