Fuel tank pressure sensor replacement.
Old Jan 25, 2018
maizemaizemaize's Avatar
maizemaizemaize is an unknown quantity at this point
Hi, I am trying to replace the fuel pressure sensor. I cant figure out how to remove the old one. There is a clip that holds it in and I cant figure out how to remove it.
Old Jan 26, 2018
Re: Fuel tank pressure sensor replacement.
Try pushing on the clip instead of pulling. IDK, maybe you have to spread out the legs of the clip on the hidden side before it will pull out.
If all else fails, remove the whole assembly from the car so you can take it apart on the workbench.
Old Jan 26, 2018
i hate plugs too. never can see where the tab to push for release is...
easy in, hard out, like eating something spiky
Old Aug 14, 2020
Kyle Shelledy's Avatar
Kyle Shelledy is an unknown quantity at this point
I am trying to replace this as well on my 2013 Si, where is this sensor located? Is it inside the pump assembly?
Old Aug 14, 2020
No. It's with the canister
Old Dec 13, 2020
mickblock's Avatar
mickblock is an unknown quantity at this point
Angry Re: Fuel tank pressure sensor replacement.
Originally Posted by ezone
..maybe you have to spread out the legs of the clip on the hidden side before it will pull out.
Yep I joined this forum just to verify that access to the back of the clip is required. I finally dropped and removed the whole can. Not doable from the front. Wow. I was able to use a pick to push out and to the side on just one of the legs.
I know this thread is old but I ended up here from google, and just wanted to verify this info, so others wouldn't waste their time playing around like I did!
sase1128
Aug 10, 2020 06:32 AM
Pochop1964
Sep 11, 2018 09:37 AM
kagan21
May 27, 2017 08:22 PM
stephen25
May 18, 2013 03:58 PM
Mex
Engine Swaps
Oct 16, 2004 10:13 PM
