2007 civic engine block problem
Old Jun 28, 2011
Kunal Bhatia's Avatar
Kunal Bhatia is an unknown quantity at this point
My 2007 civic engine block had a hole and was still starting and moving about. We I sent it to the dealership they were shocked first then I mentioned to them about faulty 2007 engine blocks replaced by Honda. Now they called me and told me that because my civic had a problem that I went thru some heavily clogged water road and thus the shifting rod (which generally bends on water coming in the engines) got bent and thus I tried to self the engine which in turn damaged the piston, broke the connecting rod and made a hole in the engine block.*
As my four year warranty finished one month ago and the insurance will not register the claim as it is non accidental they are asking me to foot this huge repair bill. 9000$ approximate ( four lakhs Indian rupees) half of what my car maybe worth.*
Can you *help me technically and what can I do. Please help me.*
Old Jun 28, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: 2007 civic engine block problem
So sorry to hear this Unfortunatly if they can absolutely postively prove that you hydrolocked the engine you have no leg to stand on because there is no warranty that will cover that kind of damage. You can bring the bill down however if you do it yourself, find an engine for cheaper for the dealer to install might save you a little bit.... Or you can try to prove that it wasn't in fact hydrolocked somehow which is possible and have them pay for the bill. Maybe get a second opinion from a mechanic that isn't associated with the dealership to make sure they are being truthful.
Old Jun 28, 2011
I was in the thought that your engine would completely seize (usually) when it hydro locks. It does NOT sound like that was the problem in my civic. I can prove as my civic was able to start and move about. I am no genius please advice if this fact is true.
Old Jun 28, 2011
BlueEM2's Avatar
Whachya lookin at?
Not necessarilly... There are a few ways your engine can hydrolock and it's possible you got water only in one cylinder bad enough to seize it.. If the engine continues spinning with a seized cylinder it could quite possibly pop a shaft out of the side and the rest of the engine continue functioning. You need to confirm with a mechanic.
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
dooner24
Apr 14, 2015 07:51 PM
