non-VTEC to VTEC Head swap place your information/questions on swapping the engine head from non-VTEC to VTEC
VTEC question - D17a1 swap FROM D17a2
Old Aug 9, 2020
2civic's Avatar
2civic is an unknown quantity at this point
in need to put a 04 A1 into a 01 A2 body
the A2 thru the rod i have a A1 that is good
i see a round part next to air filter that bolts to the head
on the A2
Old Aug 9, 2020
Re: VTEC question - D17a1 swap FROM D17a2
a1 short block + a2 cylinder head + new head gasket from honda
Old Aug 23, 2020
2civic's Avatar
thank you i was worried about metal shavings in head
do i have to get new head bolts?
Old Aug 24, 2020
Colin42's Avatar
As long as the OEM bolts aren't damaged they are reusable, think they're pretty cheap new if you want the piece of mind
Old Aug 24, 2020
you will likely get a engine light for not having VTEC unless you use the A2 head. Just reinforcing this.
Old Sep 2, 2020
Yes that is certainly possible.
drewskie211
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Aug 23, 2018 07:59 PM
Integrapros
Jan 19, 2017 11:56 PM
brobo
Sep 18, 2010 04:53 PM
bigmax1665
Jan 21, 2007 08:50 AM
CivicMexicano
Sep 26, 2006 01:04 PM
