Glossy/Shiny interrior paint
Im looking into painting my dash white, but some of the paint jobs i have seen look really dull, is there a way to paint the peices so they will have a glossy/shiny coat on top? what kinda paint should i use? and what should i do before i start painting?
Thx,
-Drew
Thx,
-Drew
i wouldn't paint the dash too shiny, you'll get lot's of glare from the sun. I'd go with a flat white, rough up surface to be painted with medium grit sandpaper, wipe, paint primer white, then paint your dash with flat white paint.
I painted mine white and just used a lot of clear coat and it is shiny. I lost count on all the clear coats I put on after about 6 times just make sure to let it dry thoroughly between coats.
Sep 27, 2015 11:33 AM
