Damn, how do I get rid of small chips on the hood?
Old Sep 1, 2005
blouisgod's Avatar
Life Begins > 6800rpms
I used meguairs cleaner wax and then tech wax and it covered everything really well and made everything nice and smooth. a week later the little white specs are back on the black hood. its obviously from the damn roads in NY, so what works best to hide (cure) the problem, other than getting a CF hood?
Old Sep 1, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
repaint or touchup. if they are actual rock chips in the paint, you cant repair them without painting it or using touchup paint. obviously repainting it will look best/ to limit the amount of white in there use a wax like meguiars NXT that dries clear.
Old Sep 2, 2005
blouisgod's Avatar
i used the meguaris NXT tech wax. you cant feel the small, small "chips". it looks like gray tiny tiny dots - the cant be fixed with touchup paint. im guessing its chipped clear coat. im just looking to see if a glaze would help my cause - im going to use cleaner, polish, and NXT wax on the front bumper today to see if it does anything.
Old Sep 2, 2005
you can try using scratchX and if you have a DA polisher like #80 and if thats not enough even #83. if you are going to use touchup paint, make sure the chip is completely cleaned out. otherwise the paint wont ever hold right and it will just fall out. you can use a clay bar to remove the wax you just put on so that you are using a clean surface. i would just try the clay bar and see if that takes them out, if not i say use some scratchX by hand because it will remove a little clear coat. if your trying to get it out you will want to avoid using a cleaner/wax because you dont need the waxing properties, thats why i say use scratchX because its a pure abrasive thats diminishes into a polish.
mrohitredd
40
Sep 9, 2017 12:03 PM
muniorbust
33
Aug 31, 2015 08:59 PM
OH5LXSE
Jul 28, 2015 12:21 PM
Smokahontas123
Jul 22, 2015 10:07 PM
cyc
Jul 22, 2015 01:14 PM
