best buffers?
Old Jun 24, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
best buffers?
what is the best mechanical buffer in the 150 and under range? and how do you get the hard water marks off of your windows?
Old Jun 24, 2005
civicrice's Avatar
civicrice should not be trustedcivicrice should not be trusted
soonercivic might be able to help you with the buffer question, he knows his ****. But to get the hard water marks off the windows u need Clay Magic (Red) the red clay. Just work it with the lube, it'll come off.
Old Jun 24, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
^^ hes right on the windows. Another option is to try using a polish, sometimes, depending on severity that gets them off too. But try the clay first, use some quick detailer as lube. If its etched into the windows then its a lost cause, the cost of getting them out would be less than replacing the window. The best thing you can get would be the Porter Cable 7336. If they have lowes in your area, if they dont you can order it, they have it for 99 bucks. Thats what i use. The one at lowes is actually model number 7336SP and comes with a "polishing pad". All that pad is good for is removing wax. You can put a microfiber bonnet over it and it works great. Other than that you will probably need to invest in a backing plate and some pads. This is what i use http://meguiars.com/estore/product_d...em&sku=W-DAV99 You will also want to pick up a few extra pads because you will only want to use one product on each pad even after washing them. Also its nice to have a few extras in case you drop one or something. The link has 1 backing plate (all you need) and 2 W-8006 pads (polishing or using abrasives) and 1 W-9006 pad (applying wax). The nice thing about that system is that they use velcro backing plates so its easy to switch pads.
Old Jun 24, 2005
BaLisTek's Avatar
i like shiny cars
BaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant futureBaLisTek has a brilliant future
Could not agree more with sooner. I also suggest some nice plush MF towels for removing the product. I watched myself put hairline scratches when i was removing the product b/c i was using an ok towel. Your questions have been answered pretty much in full.... makes me feel this post is worthless. Listen to sooner.. he almost knows as much as me about detailing
J/P
Old Jun 24, 2005
J/P
^^ he said almost hahahaha jk. The towels are a must! The only time you use terry cloth towels is when cleaning metal parts (engine, suspension, etc.) Also you would benefit from using a high quality wash mit. This is what i use http://meguiars.com/estore/product_d...itt&sku=X-3010 (saved many scratches)and i use this for wheels cause i dont wanna scratch my new rims http://meguiars.com/estore/product_d...nge&sku=X-3030
Also a tip: remove your rims, use some degreaser on them to get them spotless and dry inside and out, and then use Meguiars NXT wax on them. The brake dust will just wipe or wash off and the water will bead up. Great for painted or polished rims.
Old Jun 26, 2005
danase's Avatar
danase is an unknown quantity at this point
The Porter Cable is by far the best bang for the buck!
Try clay for water spots and if that does not work try Poorboy's Professional Polish. It is a chemical polish that contains no abrasives.
Old Jul 1, 2005
shimo's Avatar
shimo is an unknown quantity at this point
You won't find a Porter Cable for under $150 though..
Old Jul 1, 2005
ojay's Avatar
ojay is on a distinguished road
you can get one at home deport or lowe's under $100 US no problem.
Old Jul 2, 2005
Yup, the 7336SP is 99 bucks at Lowes.
Old Jul 3, 2005
rckdrmr's Avatar
rckdrmr is on a distinguished road
buy the pc at lowes (around $100) and order a backing plate and some pads (at least three) and you'll be good to go.
PiNoY Ep3 SI
Detailing
46
Sep 12, 2015 08:34 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
dre2600
Alberta
Sep 16, 2004 10:17 PM
Flash31
Detailing
Jun 24, 2003 09:06 PM
ZSKCivic01
Detailing
Feb 4, 2003 01:38 PM
