Spider web effect
Old Oct 5, 2004
NoahThePimp87's Avatar
NoahThePimp87 is an unknown quantity at this point
Spider web effect
Alright, every time i look closely at my paint when it is sunny I see what people say is the spider web effect. I have tried everything! Zymol cleaner wax by hand and orbital, meguiars paste cleaner wax, that eagle 1 polish and wax in one, by hand and orbital. And i have tried some other things including swirl removers.. I have read and studied autopia and many other websites as well. Nothing is giving me the info i need. Can anyone reccomend some product that will take that spider web effect out of the paint and how should i go applying it? Do i need a rotary, orbital, etc?
And does anyone know a good tire gloss?
Old Oct 6, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
If you studied Autopia and still did not find your answer....something is wrong! LOL
I woudl say you are not using something abrasive enough. Since you are doing it by hand I will suggest Meguiar's scratch X. That is supposed to be a good product for hand application. Stay away from cleaner waxes to get defects like that out fot he paint. The best thing would be to get a high speed orbital and learn how to use it.
Old Oct 6, 2004
obguam's Avatar
obguam is an unknown quantity at this point
Buy a porter cable 7424 and a set of foam pads. To polish out micro abrassions you will need an medium abrasive polish like Meguiar's DACP or Poor Boys SSR2.5, applied with a cutting pad, followed by a lighter polish and polishing pad to restore shine. Bobbyd's right though, there's much to learn about product choices and techniques to remove, rather than merely hide swirls, and as much about how not to cause new swirl marks. The Autopia guidebook is best place to start. Worked for me and I hope it works for you too.
Old Oct 6, 2004
bobbyd's Avatar
Yeah, the guidebook is great, and so is Meguiar's DACP and Poorboy's SSR2.5. I recommend Lake County 7.5" foam pads and a 6" backing plate if you do get a Porter Cable.
Old Oct 6, 2004
alright sounds good, ima go have to check some of that stuff out. How much is that porter cable 7424? and earlier today i bought and applied meguiars 7 and then finished it with 26 but it still showed up. And i also have the scratch x stuff already but have not tried to apply that yet, so i will have to try that one out.
Old Oct 7, 2004
bobbyd's Avatar
You can usually find the Porter Cable polisher/sander at Lowes for $109.
Old Oct 10, 2004
jonw440's Avatar
jonw440 is an unknown quantity at this point
PC 7424 With Sonus Pads
I have two complete sets of the Lake County pads. They "where my favorites"
Now I use the Sonus Pads.
The Spider webs you are seeing are also called "Swirl Marks". they are very shallow scratches in the clear.You need to polish them out.
Here is a car I did that also had swirl marks.
The polish I used was 1Z Paint Polish then followed up with 1Z Metallic Polish. Menzerna is also a polish I use.
Paint Polishes
ID:	40628   Click image for larger version
ID:	40629   Click image for larger version
ID:	40630   Click image for larger version
ID:	40631   Click image for larger version
ID:	40633   Click image for larger version
Old Oct 13, 2004
beautiful, very well done, that will help out a lot. Now what kind of pressure are you putting on the buffer, and what kind of buffer is that?
Old Oct 13, 2004
nevermind on the buffer question, just saw the link
Old Oct 13, 2004
jonw440's Avatar
The only pressure I use, is the weight of the PC. I use a light touch but polish a little longer than most people. Say 5 minutes on one section. The less pressure you use the easier it is on the buffer,s bearings, the more the polish can work and the less mar marks you may get from pushing to hard. Plus if you push hard you sloww the buffer's orbits.
Old Oct 13, 2004
hustlelikem0fo's Avatar
Paint Polishes
looks like you let one loose on your fender.....
Old Oct 14, 2004
jonw440's Avatar
I told you I was extremely happy with 1Z polishes.....
Old Oct 14, 2004
bobbyd's Avatar
The black looks good !
Old Oct 16, 2004
civictuner's Avatar
civictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trusted
Looks like some shot spearm on ur fender haha LOL!!!!!
Old Oct 18, 2004
MeguiarsEM's Avatar
MeguiarsEM is an unknown quantity at this point
Sometimes cleaner waxes aren't agressive enought to remove below surface defects like swirls and scratches. You'll need a pure cleaner to take care of spider web and scratches. Try Medallion paint cleaner a few times on the defects. If that doesn't remove the defects you're looking at something that needs to be taken care of by machine. Perhaps a Dual Action polisher. What kind of "buffer" did you use with on you paint? Was it variable speed? Reason i'm asking is sometimes people use the old wheel style buffers and those are fast enough to remove defect and are mainly for applying polishes and waxes. As far as a tire shine Meguiar's Hot Shine is a good one.
Old Oct 18, 2004
i used one of those orbital buffers that you can buy at like meijer or target. And it is not a variable speed. Its actually a pretty crappy buffer
Raiool
Oct 1, 2015 10:42 AM
MamaBear2015
49
Sep 29, 2015 01:12 PM
Dave Brabant
Sep 12, 2015 08:39 PM
Bikergofast
Sep 12, 2015 01:36 PM
johnsoda
Sep 6, 2015 04:00 AM
