removing the "Civic" and "EX" sign
Hey guys. I'm positive this has been addressed before but I just can't find the thread. What's the best way to remove the silver shiny "Civic" and "EX" signs from the back? Can they be later put on? Thanks in advance.
Take a heat gun or a blow dryer for a long time and sit it on the whole entire sign..And then with dental floss take it off slowly..you'll have residue left so you have to take a clean cloth and maybe rubbing alcohol...I forgot what I used for it..but should do the trick..
I used a screwdriver wrapped in cloth to pry it off. It worked, the the screwdriver slipped and hit the paint a few times
Then use goo gone to remove and adhesive, and wax the area.
Then use goo gone to remove and adhesive, and wax the area. Joined: May 2003
1) Just peel off the emblems
2) Take some Simple Green and spray it on the sticky stuff.
3) take a credit card and start making a sawing motion ( up and down) at about 45 degree angle and it will instantly come off.
4) continue to spray simple green as it dries up you gotta keep it wet.
Took me 3-5 minutes
Took me 3-5 minutes
i took some fishing wire and used it in an up & down saw motion and it took the emblems right off. push the remaining sticky residue up into little *****, and most if not all should peel right off. afterwards i sprayed some bug & tar remover and it got whatever was left behind.
heat gun & fishing line is perfect to do this... you can generally just roll it off with your fingers if there's any residue after... if you want to re-apply it, 3M makes an awesome "molding tape" that can be used to put it back on.. it comes in a little roll w/ red peel-off for the tape... it's about $4-5 for a little roll @ walmart here
it was real easy to get off the emblems, i used the screwdriver method it worked great for me,just make sure you are gentle so you do NOT scrape the paint, i also removed the "h" emblem then the white tabs that were plugged into the trunk with needle-nosed pliers, i had planned on just covering it up with the "h" painted a custom blue, but the white tabs looked like crap without any thing in them
I did my civic badge, but scratched the paint, so I put it back on. I have some of the tape, but it makes the emblem stick out. 3M also makes a tube of stuff that's specifically designed for reattaching emblems on cars. It's sort of like a silicony substance. You dab some on the back of the emblem, stick it on, and you're good. The scratches are really hard to notice, though, and I might take it off again as well as my EX emblem. I would recommend using a hair dryer, then a credit card to take it off. Comes of EXTREMELY easily after heated.
I used floss then cleaner wax and it came right off to problems at all. especially if you use stronger stuff like tar remover, you'll want t to wax since you probably stripped any kind of protectant from the surface that was there off.
I know this thread is a bit old, but i'm just getting into modding my 04 civic ex's appearance.
are all of the badges/emblems on the 04 just glued on or will some of them have the alignment pegs that'll leave holes?
The "Civic" and "EX"/"LX" etc will come right off, no holes. the "H" in the top middle has two holes.
OK I did this last weekend & didnt have any goo-gone or simple green, BUT I did have some Meguiars Step 1 cleaner. Spread some over the residue, let it sit for ~3-4 minutes, wiped it with a cloth and it was all gone!! Already!!
Bush fu(king party,mother fu(king hand job.
i just did my "civic" and that fugly "30th anniversary edition" emblem today! i heated with blow dryer since it was cold today and took them off with fishing line. a lil goo gone and all i have to say is...my god my car's sexy!
I used a flat head and cloth. My flat head poked through my cloth a few times so i had to keep watching out for it, but it ecentually put a little scratch right above my "LX", but it is barely noticable. I live in Texas so it was already pretty hot (it had been sitting in a parking lot all day). They are not worth reapplying if you ask me. Buy some from the dealer for like 10 bucks if it's that big of a deal, but i think the civic emblem looks kinda cool.
muttleytm
Jul 11, 2015 06:00 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
ballmich
Jul 9, 2015 11:59 AM
