SOHC D17Ax non-VTEC - VTEC Engine Swaps Post information/questions about non-VTEC VTEC D-series engines here.
JDM d17 motor swap question
Old Jun 20, 2016
  #31
valdie's Avatar
valdie is an unknown quantity at this point
Re: JDM d17 motor swap question
Hi how did your swap worked out? I did a swap in my 02 to a 05 motor and I can't seems to get my engine light off.
Old Jun 20, 2016
  #32
valdie's Avatar
Re: New member in Arkansas
One next question can I run a d17a2 ecu with a d17a1 motor?
Old Jun 20, 2016
  #33
Post moved.
You can't use the PCM for an A2 engine on an A1 engine, it will set fault codes for the missing VTEC system and will stay in limp in mode.
Also, the primary O2 sensor on an 02 became an AF sensor on the 04-05 so that has to be swapped
What fault code(s) do you have?
Old Jun 23, 2016
  #34
valdie's Avatar
HI guys I did a engine swap from my 02 civic. I replaced it with a 05 civic motor now I have 02 sensor problems can any one tell me if 02 civic 02 sensors is different from the 05 civic
Old Jun 23, 2016
  #35
valdie's Avatar
Originally Posted by ezone
Post moved.
P0134 02 sensor bank 1
Old Jun 23, 2016
  #36
The engine type is.....?
The engine year is....?
The car year is....?
The car type is....?
The PCM year is....?
The PCM type is.....?
Engine wiring harness came from ....?
Old Nov 8, 2016
  #37
levan's Avatar
levan is an unknown quantity at this point
please help me, first sorry for my english. i have usa civic 1.7 vtec, 4 door sedan, first the car was engine d17a2, i put there jdm d17a, i want ecu too d17a but when i plug the ecu there is rpm only 5000, i havent vtec, what is problem? ecu is d17a but from variator car, my car is mechanic... what i want to replace??? please answer...
em2_k20a
May 19, 2015 03:36 AM
Supramk3
May 11, 2015 07:55 PM
vtechcivic
Apr 21, 2015 07:11 PM
NROD315
Apr 16, 2015 08:40 AM
viper775
Dec 9, 2001 10:52 PM
