Transmission swap post information/Questions about automatic to Manual Transmission swaps
Help with Swapping Auto Transmission
Old Mar 4, 2005
Civicious's Avatar
Civicious is an unknown quantity at this point
I am going to swap out my automatic transmission on my 2001 Civic DX this weekend.
I have heard many people are able to pull the tranny without dropping the sub frame or puling the engine. Does anyone know how I can pull the tranny through the top of the bay. There used to be a topic on this by a user named "Doober" but I can't find it anymore.
Any help is appreciated.
Old Mar 4, 2005
MarylandEcstasy's Avatar
You cant spell CRAP without APC
MarylandEcstasy is an unknown quantity at this point
If you check the DIY engine swap with the K20, you'll find that our engine bay is too small to lift the motor / tranny from the top.. you need to find a lift and do it from the bottom
Old Mar 4, 2005
Civicious's Avatar
Thank you for your reponse MarylandEctasy.
However I am not doing a K20 swap. I am swapping a transmission with another transmission of the same type. I have not read the thread you are reffering to but I can tell you first hand that it is inaccurate if it says you cannot pull a d17 from the top. I know first hand that you can. I have pulled my engine with transmission attached right through the top of the engine bay. What I am asking now is how to pull the trans straight through the top without the engine attached. I know it's possible cause someone did it in the past. Unfortunatley the user "Doober" who did it cannot be loacted on this site anymore. I am hoping someone else has experience with this?
Old Mar 4, 2005
Civicious's Avatar
Mods can you please move my thread to Tech Stuff? I realize this is the wrong Forum cause I am not reporting a problem I'm looking for a solution.
Thank you!
Old Mar 16, 2005
Civicious's Avatar
Well I wound up pulling the entire motor with tranny attached through the top of the engine bay again. Car runs like new after I swapped the tranny out.
Old Mar 16, 2005
blouisgod's Avatar
Life Begins > 6800rpms
Damn, nice work.
How hard is it to pull the trans out? I'm thinking of doing my own clutch and flywheel replacement.
Old Mar 16, 2005
Gangsta Dave's Avatar
People Eating Tasty Animals PETA
Gangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to all
pics?????
Old Mar 16, 2005
Civicious's Avatar
Well a long time ago someone mentioned they were able to pull the transmission by separating it from the engine while still in the bay. However, I would have likely spent more time trying to figure that out rather then just pulling the entire motor and transmission all together.
I have an automatic so I am not sure how different/hard a clutch and flywheel would be. I would imagine they would be quite similar in disassembly. I would say if you haven't had experience using engine hoists or doing something like this before, don't do it by yourself. I had help from an experienced friend who has swapped a Ford V8 into his 4 Cyl Jeep.
The hardest part is pulling the motor out without scraping the various pieces of hardware on the firewall and fender wells. But we managed to do this without damaging anything. The other bitch is aligning all the mounts with minimal space to work when putting the engine/tranny back in.
Unfortunately I didn't take pics this time. My digital camera is very nice and I usually had various oils and grease all over my hands anyway.
Last time I took a few pics when I swapped out my engine but the pics were by far not DIY worthy.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
lapchern
Jun 4, 2015 04:35 PM
MajTom
Jun 2, 2015 11:48 AM
Schneiderman
May 24, 2015 01:14 PM
Rinzlor
Apr 24, 2015 10:33 AM
