Hondavert in my first ep3 (European)
Hi finally got a car I’ve always wanted since I had my licence and so far it’s living up to expectations
it’s an 05 model in black does need work but it’s not a problem.
the problem is it’s got a hondavert Ecu and I cannot find much info on it it has a barometric pressure circuit high input problem that’s intermittent.drives great when lights off
Question is can I go far wrong by downloading the software to a laptop and having a look?
thanks in advance
thanks in advance
re: Hondavert in my first ep3 (European)
So you’re running a KPro emulator?
I’d take it to a tuner. Bad tunes can go south very quickly.
Yeah from what I gather it’s a copy
there isn’t many tuners within a sensible distance of me I’m in north wales it’s like the end of the world for technology
as my fault is intermittent is there a chance it could be the map sensor in the tb?
and told me I would be hard pushed to find anyone in the UK who would and suggested I change to Hondata for a whopping £800+, don't need the ECU rewiring just need the board,
mine is already re wired
thanks in advance
thanks in advance
Hi
Did you find a solution for this problem other than replacing the ecu? I'm having the exact same issues and also have kpro v4, but i cant access the Map installed by tdi North and can't find anything in the settings relating to the barometric pressure sensor. I dont want to create a new programme and delete the map I already have. Any information would be great as its becoming a nightmare.
thanks
thanks in advance
thanks in advance
Dynodaze @ Nuneaton remapped mine to 225 BHP, because I have a few restriction issues, induction kit too small and a Spoon N1 backbox
vtecPortugal
Jul 24, 2002 01:20 PM
pleasejoe
Jul 21, 2002 03:55 PM
thx1138
Jul 17, 2002 05:35 PM
