Engine Management Post information/questions about Engine Management here! It's especially important for Forced Induction (Turbo and SuperCharging) and Engine swaps! What destroys engines are fuel management!
4.5 mm x 11mm keystock for the crankshaf
Old Jun 14, 2021
Reinhardrules's Avatar
Reinhardrules is an unknown quantity at this point
Previous owner failed to put this keystock in whenever they did whatever they did. No damage besides valve cover. Got a replacement for that arriving tomorrow
Anyways I'm putting the little guy in
do I put the sprocket all the way against the spacer between the sprocket and oil pump?
I assume yes. But just figured I'd ask the vets
Only reason I noticed this is because I had to replace that awesome little o ring on the oil pump (don't worry I didn't mess the timing up, I have the crankwheel locked in place and marked the belt and sprockets and pulleys before I removed anything)
Thanks in advance!
Old Jun 14, 2021
BrotatoChip's Avatar
Super Moderator
Re: 4.5 mm x 11mm keystock for the crankshaf
From the oil pump you have the timing belt guide plate thing, then the timing belt sprocket, the lower timing belt cover, then put in the key and install the crankshaft pulley.
Old Jun 14, 2021
cool. Makes perfect sense.
Thank you
MainFrame
Apr 4, 2018 09:44 PM
Ohyaimember
Feb 28, 2017 06:52 PM
moorebl
Jul 29, 2014 10:01 PM
5ltrdrmr
Apr 13, 2014 06:32 PM
metfan53
Apr 20, 2012 11:16 PM
