Why can't our ECU's be tuned?
I'm wondering why our ECU's can't be tuned. Correct me if I am wrong, but my understanding is that all OBD2 ECU's must be capable of accepting updated software, at least from a dealer scan tool. To me, that would mean that it is possible to reprogram it for improved performance. Is there some reason that no one can? Is the problem that no one has figured out how to trick the ECU into thinking that a dealer is updating the software so the ECU will allow it, or is there some other reason why no one can tune the stock ECU on these cars? Thanks
Re: Why can't our ECU's be tuned?
You can tune them but there is no aftermarket option, premade.
You would have to find out what programming language the ecu is written in, and have the right connectors to read and write date. There may also be anti tampering software installed that you'd have to jail break.
There are some interesting diys on youtube that explain the process for other cars.
This used to be called "chipping" because people would write new maps for a certain ecu, then clone the changes onto chips to sell, that would replace the original chips on an ecu.
Another interesting that I found is that there are plenty of products available like this one to supposedly tune a Honda Stream 1.7 ECU (the ECU I have in my car) as well as the Edix, such as this one: https://www.gantuning.com/chiptuning...ad/1-7i-125hp/
There are also services in Asia and Europe to tune the Stream 1.7 as well as the Edix 1.7, with advertised power increases of 8-15+ HP. No idea if any of those products or services are legit, but it makes me wonder if there is some difference in the foreign ECU's that makes tuning easier or possible, like maybe a lack of anti tampering software. Or maybe all of those products and services are total scams, who knows.
Those hp numbers sound reasonable.
I'd guess it's a simple air/fuel remap, probably a device that intercepts the O2 sensor and tells the ecu its rich, so that it leans out.
Lean is mean as they say... but what they don't tell you is that lean can also go pop-pop bang and detonate your engine. Lol
Depends on the model, honda have a larger closed loop setting than most cars.
Many manufacturers are in open loop from 80% throttle plus.
But depending on the vehicle from honda the MAP sensor is also consulted. So you can be in a gear higher than what would give you maximum torque, at 90% throttle, with a lower MAP signal because your rpm is low.
Example would be highway cruising at 3000rpm, in fifth gear at 80%.
https://www.k20a.org/forum/archive/i...p/t-13276.html
Here's an example of what I meantiond above. If you're interested in similar information, Google "honda closed loop WOT"
I'm not sure, but ignition timing advanced across the whole air/fuel/ignition map, isnt the best route to power.
If you look at a dyno tuned car the ignition map will show 0 advance in some locations, as well as positive and negative values.
I'd suspect that with a set value for you would see ignition problems somewhere within the map.
The main regions which differ from each other are
-idle
-low to mid acceleration
-low to mid deceleration
-vtec cross over
-mid to high acceleration
-mid yo high deceleration
-these groups are also effected engine load and MAP readings
There will be larger variations between these regions than within them.
-idle
-vtec cross over
http://twinturbo.net/nissan/300zx/fo...your-ABCs.html
This link shows some different regions for high octain ignituon tuning. You can see retarded values, no change, and advanced values.
You can also see that within a region the values may only change by two or three units, but across regions change by larger amounts.
