Engine Management Post information/questions about Engine Management here! It's especially important for Forced Induction (Turbo and SuperCharging) and Engine swaps! What destroys engines are fuel management!
emanage/AEM EMS
Old Feb 24, 2005
deciuss's Avatar
Boosted Auto
emanage/AEM EMS
who is running what? the shop that i always take my car to wants to change me over from greedy to aem. he said its eazyer to tune. but i just cant justify spending 2 grand like the aem site says there tuning dodad costs.
this summer im droping lots of cash into my car to finish it off. i plan to run more then 15psi should i stick with the greedy profec e-01/emmanage set up that i have now or go with an aem set up and spend 2 times as much cash. will the emanage be able to run that kind of psi.
Old Feb 24, 2005
C2i0v0i1C's Avatar
SuperMODrizd
AEM is better of course, it just depends on the wallet.
Old Feb 24, 2005
exturbo6's Avatar
What makes AEM management better then emanage?
Old Feb 24, 2005
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
i think the emanage is a piggyback system, while the EMS is a complete standalone...not to mention is has a ton more features than the emanage...correct me if i'm wrong, i'm not a wiz when it comes to engine management.
Old Feb 24, 2005
TheSmuggler's Avatar
Your right, and the AEM has alot more fine adjustment abilities, but I believe you could get away with 15 psi on an emanage, but when you get serious, like 20psi your gonna want a stand alone ems
Old Feb 24, 2005
civic01vtec's Avatar
15psi....i hope you are building your bottom end.
Anyway......there is no question that the AEM ems is better than e-manage.....it just depends on your budget.
Old Feb 24, 2005
Mirage's Avatar
Mirage is an unknown quantity at this point
It's really tough to even compare the two. They are aimed at different markets and have very different capabilities.
Old Feb 25, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Yeah the emanage is a great unit for the money and really there are no problems with it. What does pose a problem for us 7thgens is the barometric pressure sensor in our ecus. you can only upgrade the injectors so far before you trip a code(cause of fuel correction). So its not the emange thats the problem, more the inflexibility with our ecu. I should have my 30-1070 and a 3.5 bar map monday hopefully. This spring i will be running a full build with the standalone so I cant wait to see what the civ runs on 15+psi. at 6 it was a descent improvement. I plan on stockpiling some trannys in the basement lol
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
Civic_RedLine
Engine Swaps
25
Jun 14, 2005 11:12 AM
02fpcivic
Apr 21, 2005 05:45 AM
Mirage
Engine Swaps
Mar 4, 2005 02:47 PM
canadian2k1si
Engine Swaps
May 20, 2004 03:39 PM
