Forced Induction Post information/questions about Forced Induction here.
Boost Head Gasket
Old Jul 9, 2023
2StepRooster's Avatar
2StepRooster is an unknown quantity at this point
Boost Head Gasket
Hey guys! Have to replace the head gasket on the 1.7. Going to pick up a decent turbo kit for some boost. I will be port matching the head and using a quality kit. Will a cometic HG be enough for 7-10lbs? Will be using an ARB stud kit. Thanks
Old Jul 10, 2023
chozobody's Avatar
chozobody is an unknown quantity at this point
Re: Boost Head Gasket
TBH with studs a factory headgasket should be fine. So yes, a cometic will be fine.
What are your plans for internals?
Old Jul 10, 2023
Cool that will save me $100, thanks
Old Jul 11, 2023
After more research I think I will just stay stock on internals and stay under 8lbs. If it gives up the ghost I will look at a better set of rods and wiseco pistons and more boost.
Old Jul 11, 2023
BrotatoChip's Avatar
Super Moderator
I will only say this once because you seem determined, but you could also K swap. A K24a2 swap will get you 200 hp and 165 lb ft (granted at a much higher rpm). Can run a stock tune or get Kpro/tuned and make even more. Naturally aspirated so arguably more reliable for daily driving. Responds well to mods. Still tons of fun and feels very sporty. Night and day difference over the stock D17.
Old Jul 11, 2023
An upswap is never a bad idea. And I fully understand the d17 will peak pretty quick where as the K model engines have a much much higher ceiling. Honestly I want to have a fun little car that has the turbo sound as nd that woosh when you change gears lol. I was making 485hp at the wheels in my S4 but just wanted something different and knew this was going to be much slower. I do appreciate the advice as it's very good advice. I'm just going to throw a swirly bird on this for now 😂
Tracecross30
Feb 2, 2020 06:18 AM
alterman156
Mar 8, 2019 04:41 PM
siguy2
Mar 19, 2015 09:10 PM
HyaBoosta
Engine Swaps
43
Sep 6, 2004 07:11 PM
Roy
Apr 12, 2002 11:11 AM
