Engine building Post information/questions about Engine Building here!
2005 Honda Civic EX Coupe Camshaft
Old Dec 17, 2021
IfollowUdie's Avatar
IfollowUdie is an unknown quantity at this point
Hey everyone I need some help with a cam I just bought off of someone. I have the specs for the regrouped cam vs the crower specs and need to know if I got ripped off or not as I have no idea how to really read these. I need to know which stage it's closest to.
I hope I didn't just get screwed over...I also have springs and these weird small things that I have no idea what they are...
Yes i have springs they look so long lol
Old Dec 17, 2021
FRSam's Avatar
Click Here
Re: 2005 Honda Civic EX Coupe Camshaft
It looks basically like a 1.5, halfway between stage 1 and 2. Looks like it came with valve springs and retainers.
If you were unsure, why bother buying it?
Old Dec 17, 2021
Because honestly for $350 it's not bad. Thank you for figuring that out because I don't understand cam numbers. Should I install the springs and retainers? And should I run a tune or would it be safe to just slap it in there? Also I have no idea how to install one in the first place so gonna have to learn how that works. I know timing will most likely need redone, and I know there's a specific way it needs to go in but that's it. I might lower my engine from the bottom a bit so I can actually do the timing again easier. It's a b**** with it all the way in.
Old Dec 17, 2021
the box says D16, you have a D17.
Old Dec 17, 2021
Holy crap your right...I guess I have to buy that stuff again now unless it's super simaler?
Old Dec 17, 2021
Colin42's Avatar
Also if the cam comes with new springs and retainers you should probably go ahead and put those on
Old Dec 17, 2021
As above states the springs and retainers are for the D16 Y and Z engines. Do you or anyone know if these are compatible parts with the D17A?
Old Dec 17, 2021
FRSam's Avatar
Click Here
D16 cams have been put in D17 heads, but they require a ton of modification.
Old Dec 17, 2021
Uts an official D17A2 cam so I'm not worried about thst. Just the springs and retainers are for the D16 Y and Z engines.
Old Dec 17, 2021
FRSam's Avatar
Click Here
Probably. Supertech makes springs and retainers and has both the D16 and D17 as compatible engines. I would assume other aftermarket would be the same.
Old Dec 17, 2021
I would call crower and ask them just in case
Old Dec 17, 2021
Stage 1 is the only one that don't need spring/retainers nor a tune. take the opportunity and ask them about what cam you have
Old Dec 17, 2021
also, what do you mean by "regrouped cam"?
Old Dec 17, 2021
Thank you for researching that for me!!!
Old Dec 17, 2021
I tried and I left a voice mail and emailed them
Old Dec 17, 2021
Yeah I do know that, thank you
Old Dec 17, 2021
Reground stupid auto correct
Old Dec 20, 2021
BrotatoChip's Avatar
Super Moderator
I see spring seats and valve stem seals.
Ckutch02EX
Jan 15, 2010 07:51 PM
TitoTheNightKid
May 14, 2007 10:58 AM
02BLKCIVIC
Dec 13, 2006 03:45 PM
2K5CIVICBOY20
Oct 28, 2006 06:39 PM
