Engine Performance Modifications Post your questions about how to modify your engine here Swaps, Flashing, bolt-ons, etc.
2003 civic sir tuner
Old Dec 22, 2021
MrMilitary's Avatar
MrMilitary is an unknown quantity at this point
Purchased a lovely 03 civic SIR, it’s stock other then a intake.
I would like to increase the Rev limiter a tad, looking for recommendations on what steps to take and, or mandatory things to change.
More sporty responsive car with a higher rpm limit of the current 7900
on a side note it’s my daily driver so would like to keep the engine low risk in terms of pushing it to its limit as it only has 114kms
I attached a Pic of my well used civic
Im fairly certain I have a 2.0 L K20A2 correct?
Old Dec 22, 2021
FRSam's Avatar
Click Here
Re: 2003 civic sir tuner
SiR’s have a K20A3, but the stock redlines for those is like 6800rpm. Sounds to me like it’s already been done up or it’s been swapped, most likely with a K20A2.
Cosmetically they look almost identical so I can’t tell you which one you have. Look up K-series engine code location and that’ll tell you.
Old Dec 22, 2021
MrMilitary's Avatar
my mistake typo, you are correct it currently has 6800 redline not sure y I typed 7900!
still looking for advise on what to do improve to increase the rpm
Old Dec 22, 2021
you will need hondata and look if the engine can take the higher RPM.
not sure why someone would like higher RPM by itself.
Cheifbobo
Jun 13, 2018 03:18 PM
Gohondaorgohome
Jun 17, 2014 06:56 PM
purplehazedx
Mar 18, 2009 11:22 AM
purplehazedx
Mar 18, 2009 05:32 AM
Jandree22
Jul 22, 2002 02:17 PM
