Engine Performance Modifications Post your questions about how to modify your engine here Swaps, Flashing, bolt-ons, etc.
New Civic Owner. Two questions.
Old Apr 20, 2020
Laser's Avatar
Laser is an unknown quantity at this point
Smile New Civic Owner. Two questions.
So I just, against my better judgment, bought an '03 Si with K20A2 head and pistons installed on the K20A3. Runs fine, sounds like **** (exhaust is horribly raspy)
I have read that many people recommend that one uses the Type-S oil pump as well.
My questions are as follows:
1. I will just daily this car (not looking to take home any SCCA accolades with it), do I need to swap to the A2 oil pump or not? If so, is there a good write-up on the process, detailing everything I need?
2. It has the factory Si ECU. Should I get the ECU from the RSXS or the "Kpro" I keep hearing about? I assume that I will have key fob problems with either option, so what is the best way to here?
Thank you for reading.
If I missed the answer to this solution in my search, then excuse the dumb. I am trying to get parts ordered ASAP if needed to get me on the road confidently and quickly.
Old Apr 21, 2020
Colin42's Avatar
Re: New Civic Owner. Two questions.
It's fine the way it is especially if you're just daily-ing it
Old Apr 21, 2020
Laser's Avatar
If that is the case then I will get the ECU and leave it as is for a while. Then, when I finally do car about power, I will finish the K20A2 swap rather than just using the hybrid set-up.
This means I get to put my money into coilovers and exhaust that doesn't suck, haha.
Thanks Colin42
tolman8r
May 13, 2012 04:28 PM
thumperk15
Mar 11, 2012 10:29 PM
linsook
Dec 1, 2004 04:58 AM
reytito
Aug 13, 2004 05:31 PM
pnut
Aug 7, 2003 12:46 AM
