Engine Performance Modifications Post your questions about how to modify your engine here Swaps, Flashing, bolt-ons, etc.
EX sedan k20 mods?
Old May 15, 2019
evade's Avatar
evade is an unknown quantity at this point
EX sedan k20 mods?
Will soon get a hold of 7th gen ES Civic with K20A3 on it. It will be the SEA version that comes with the K20 5spd A/T 155hp from the factory. What engine mods should I start with? I know A3s are not like the A2s in terms of perfomance. I need recommendations on what route of modding should I take.
The first thing that comes to my mind is swapping a EP3 Si ECU + transmission. Any recommendation for the engine mods? Tia
Old May 15, 2019
BrotatoChip's Avatar
Super Moderator
Re: EX sedan k20 mods?
As far as I know you'd make some additional power with an intake, header, and exhaust but not much. If you want to make real power you'd have to turbo or swap to a K20a2/K24a2, both of these would require swapping to a manual transmission as well.
You could swap an EP3 ECU and transmission, you'd also have to worry about getting a clutch. This won't get you any extra power but will get you a manual.
Old May 15, 2019
mac25's Avatar
Dr Krieger of Modification
7th gen is 2001-2005 only the ep3 hatchback has a K20 engine for that year.
The others are D17 engines.
Auto is 4 speed
Manual is 5 speed
Old May 15, 2019
evade's Avatar
Auto is 4 speed
Manual is 5 speed
Yes that's for the market here in US.
This model is exactly what I'll have 7th gen 2.0
Old May 15, 2019
evade's Avatar
The problem if i get an intake, header, and exhaust is I don't know if the stock ECU of this Asia market Civic is tunable by Hondata or Kpro. If that's the case, my only route is to do full EP3 drivetrain swap + ecu.
Old May 16, 2019
Super Moderator
I'm confused what you even have. Your original post stated you have an ES Civic and a K20a3, I assumed you meant you have a four door sedan with a K20a3 and auto transmission swap. Do you actually have a EP3 hatchback?
For reference these are the ECUs compatible with Kpro. 2001-2005 Civic DX, LX, HX, and EX require using an ECU from another K series engine.
7thGenSi4
Apr 3, 2013 11:09 AM
BLEGAN
18
Apr 15, 2011 05:27 PM
Hayden
Jan 2, 2011 07:10 PM
jajell
Jun 15, 2004 08:41 AM
Marc
Dec 24, 2002 10:53 PM
