Engine Performance Modifications Post your questions about how to modify your engine here Swaps, Flashing, bolt-ons, etc.
Performance cams
Old Aug 3, 2019
Matthew Jackson's Avatar
Matthew Jackson is an unknown quantity at this point
Performance cams
Best cams to put on a d17a1?
Old Aug 3, 2019
GolNat's Avatar
Prelude Owner
Re: Performance cams
There are none. Crower can do a regrind. They sold one for the A2 head you might find used. Someone on the forum is selling a Stage 1 (piano55 I think).
Old Aug 12, 2019
crazicardi's Avatar
crazicardi is an unknown quantity at this point
These guys retrofitted a D16Y8 cam onto a D17A2 head.
You would need to swap your D17A1 head to a D17A2 head I think.
Parts needed:
AEM Adjustable Cam Gear (used with K-Pro)
D16Y8 rocker tower assembly
D16Y8 camshaft
Opens your options to the crower staged cam series.
Old Aug 16, 2019
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
You actually need to buy two AEM cam gears...one for D17 and one for the D16y8 and swap out the centers.
Unfortunately, AEM no longer makes the D17 cam gear.
I'm currently working on a prototype center gear for our AEM cam gear to utilize the d16y8 cams....because i didn't want to spend the extra 100 bucks for only the center.
Old Aug 18, 2019
crazicardi's Avatar
You're right, I forgot about needing the Y8 camgear because of the center gear. Gotta like combine the two.
You can still get D17 cam gear to use with K-Pro
https://www.hamaotorsports.com/honda...-cam-gear.html
piano55man
Engine building
33
Mar 21, 2024 03:19 AM
Freddyboom
Jun 18, 2011 11:42 PM
tribbcivic
21
Feb 22, 2008 03:30 PM
varner88
Engine Swaps
Aug 13, 2006 10:15 PM
