Engine Performance Modifications Post your questions about how to modify your engine here Swaps, Flashing, bolt-ons, etc.
help
Old Jan 16, 2015
howsurjohnson's Avatar
howsurjohnson is an unknown quantity at this point
help
I have a 2005 civic that I just put $2500 into (new engine(cracked my block) new radiator, new timing belt, new water pump, new o2 sensor, new tires, new brakes) pretty much the whole shebang. so now that its basically brand new to me id like to put it to si specs. where should I start and what do I need to do.
Old Jan 16, 2015
Poopies's Avatar
Super Moderator
Re: help
Put in an Si engine? . That or turbocharge yours.
Old Jan 16, 2015
CraigW's Avatar
Re: help
More $$$
Old Jan 16, 2015
Re: help
Buy an SI?
Old Jan 16, 2015
lowlife9's Avatar
Re: help
put si badges on it.
Old Jan 18, 2015
Re: help
Originally Posted by howsurjohnson
(new engine(cracked my block) new radiator, new timing belt, new water pump, new o2 sensor, )
You could have gone the K-swap by them, although it would cost more...
(new brakes)
you could have installed rear disc brakes conversion...
