Interior Post about Interior parts, seats, consoles, etc
What are these for?
Old Apr 10, 2019
coachJ's Avatar
coachJ is an unknown quantity at this point
What are these for?
I would like to know what was supposed to go here and on what trim or what market. The two blank plates left of the 12V socket. The purpose is to see if I can retrofit a microphone and a usb extension for a CarPlay head unit and have a factory look to it. I have done this in the past on a on my e36 m3 I used a cluster dimming switch from a junk yard to fit a mic and put it in an unused slot next to my actual dimmer. Thanks everyone.
Old Apr 10, 2019
Colin42's Avatar
Re: What are these for?
those are for heated seats
Old Apr 11, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Airborne mode and rocket launchers
Old Apr 11, 2019
BrotatoChip's Avatar
Super Moderator
I thought that is where the fog light switch goes?
Old Apr 11, 2019
They aren't being used for anything on your car right now. You can put anything you want there.
Old Apr 11, 2019
Colin42's Avatar
my fog switch went in the empty spot next to where the cruise control main switch would be
Old Apr 11, 2019
coachJ's Avatar
I don't think you understood the question. What i want is to know what OEM parts can fit in there so I can gut the part and stuff it with a microphone for hands free calling
Old Apr 11, 2019
Colin42's Avatar
just drill out a microphone sized hole and mount it flush
Old Apr 11, 2019
SMH, I know what the question was.
If Honda accessory foglights had been installed, one rectangular blank would be removed and a switch installed in the hole
The entire panel could be removed and replaced with dealer installed accessory ashtray/lighter combo.
Your car appears to have neither of the above accessories installed.
Modify the blanks to your hearts content.
Old Apr 11, 2019
GolNat's Avatar
Prelude Owner
If you want to add a headphone jack and use OEM parts I am not sure what OEM parts fit in those slots. As far as I know the 7th gen had no aux option so you would have to try one out of a newer Civic, Accord, Pilot.
You could drill and mount an aux connector though and make it look close to OEM.
Maybe measure the slot and see what dimensions a newer OEM aux cutout is.
Old Apr 11, 2019
coachJ's Avatar
Well with no luck with oem parts to utilize I’m going to try my best with these usb mounts I found on eBay. One will be for usb, the other I’m going to cut the wire and gut it and try to stick a mic in. Should look clean with the black spindly mic cover. Next option would be Drill a whole like mentioned about and glue a mic in. I have tried that before with the M3 in the past but it’s really hard to drill a whole into such a small piece. I remember it always breaking. When it’s done I’ll post some pics. Still haven’t decided what car play unit to get. Debating on if I should shell out more cash for a wireless one or get the $175 Dual CarPlay from Walmart.
Old Apr 11, 2019
Colin42's Avatar
Dual isn't a good brand in my opinion.
Check Crutchfield, that's where I got my head unit and front speakers from
Old Apr 11, 2019
If that usb port is smaller than a switch blank in your console, careful use of a Dremel tool would probably cut a nice hole in a blank to install it
If the mic is down in the same area, will it be able to pick up your voice okay? I sometimes see those hanging off the trim on the side of the windshield or a sunvisor.
In my truck I tucked a mic alongside the trim around the gauges...it's black and not real obvious LOL.
If the car has room for an upper console instead of the simple map lights, that's where Honda puts their microphones
stolen from google images
Old Apr 11, 2019
the newest 7th gen is now 13 years old... Do you think there were OEM USB ports in them econoboxes back them? You were a teenager...
Old Apr 12, 2019
Back on m 2002, I used one panel for a accent light kill switch (had blue halos at one point in time, and navy base cops didn't like them very much), and the other I made my own USB charging port.
Old Apr 13, 2019
coachJ's Avatar
you don't understand what im asking either smh. I want what ever OEM part fit there to hold a microphone. That's it. Just part numbers. I never said I want "oem 2001 usb ports" that's idiotic. I said I want to UTILIZE oem parts. I have done this before on a different car. it works good and looks good.
Old Apr 13, 2019
Colin42's Avatar
So again:
Or like ezone said mount it up higher somewhere else because it will probably be hard to hear you with the microphone that low
Old Apr 13, 2019
coachJ's Avatar
its really hard working with such small thin plastic. I had a hard time doing that with my M3, ended up gutting out a cluster dimmer and installing the mic in it. the mic went right where the wheel was that adjusted the brightness. The mic was basically behind the steering wheel and it picked up my voice just fine so it should be no different where I want to install it on my civic. Im thinking i can just drill a hole the size of the mic like someone mentioned and epoxy it flush from the back
Old Apr 15, 2019
Thin? I'm guessing you haven't actually taken it apart yet...
The "blanks" are just inserts to fill the holes. Pop one out so you can really see what you have to work with
(you might need to remove entire panel in order to remove a blank from the panel)
Mourtzy
Lighting
Aug 3, 2011 08:49 AM
cwo715
Jul 11, 2006 03:11 AM
asianmatrix02
Mar 8, 2003 01:04 AM
djk
Apr 28, 2002 01:12 AM
aldini
Mar 10, 2002 10:36 AM
