alignment question
Old Apr 30, 2003
TheHumanV's Avatar
TheHumanV is an unknown quantity at this point
alignment question
i hit a pot hole on the road recently with my front right tire, and now my car slightly drifts to the right. also my tire losses psi. wtf is up with that, id air it back up and like a day later it goes back down to like 24 psi, but no lower? some dude told me its cause my alignment that is causing it? anyone know anything?
Old Apr 30, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
might need to balance ur tires. last nite i hitted a pothole on my front 2 tires...yea its a big *** hole. at 55mph its pretty bad, but its still good doesn't mean imma do it again
Old Apr 30, 2003
TheHumanV's Avatar
so can it just be that my tire thats causing the slight drift to the right, or is that alignment
Old Apr 30, 2003
solar's Avatar
solar is an unknown quantity at this point
The tire is losing pressure because it has a leak, its possible you bent the lip of the rim and thats whats leaking. A tire cam cause a "drift" but if it started right after you hit the pothole you probably knocked the alignment out. Take the car in to the shop and have them find your tire leak and do a rotation of your tires then have it aligned.
Old May 8, 2003
slowvic's Avatar
slowvic is an unknown quantity at this point
Depending on how hard you hit it, you may also have a bent lower control arm. Just so you don't freak if the alignment shop tells you so.
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
bsmiley
Aug 13, 2015 10:32 PM
civic98?
Aug 13, 2015 01:32 AM
Dangerousjordan
Jul 28, 2015 08:24 AM
