Steady grinding noise front passenger side
Old Feb 7, 2021
civicenthusiast's Avatar
civicenthusiast is an unknown quantity at this point
Question Steady grinding noise front passenger side
I've been driving my 05 LX for years now and never heard any grinding noises... until I was driving shotgun and I heard this awful, steady grinding noise coming from the wheel area. It also makes this "alien ufo" high-pitched sort of oscillating whine noise when turning at high speeds, idk how else to describe it lol. Is this the wheel bearing? Lower ball joint?
Old Feb 7, 2021
Re: Steady grinding noise front passenger side
Sounds like it'd be a wheel bearing issue.
Jack up the front and spin that side. Take off the tire and spin the hub if you need to get your ear closer to try and determine the source of the sound
Old Feb 8, 2021
BrotatoChip's Avatar
Super Moderator
I have also had small stones, grit, and salt get stuck between the dust shield and rotor. Causing grinding/screeching noises until it knocks itself loose.
Old Feb 8, 2021
Colin42's Avatar
Wheel bearing, dust shield, or something jammed in the brake
Old Feb 8, 2021
What would cause the oscillating whine noise at high speeds while turning? Same thing or are they unrelated?
Old Feb 8, 2021
Colin42's Avatar
Probably related
Old Jun 30, 2021
EM2-EMMA's Avatar
I’m a guy. My car’s name is Emma.
EM2-EMMA is an unknown quantity at this point
I’m having the same sounds/symptoms. Could it be the cv axle? That might explain the extra grinding when turning… my boot is cut and looks like it’s flinging grease everywhere
DavidKing
Jan 20, 2016 01:21 PM
ishmot
Jan 2, 2016 09:53 AM
Cheekyboy1021
Apr 29, 2012 04:17 PM
03Civicuser
Jul 8, 2011 09:11 AM
halflife
Aug 12, 2004 03:28 PM
