Rear suspension making crunching noise
Old Jan 20, 2020
lostdriver's Avatar
lostdriver is an unknown quantity at this point
I've taken my car to 3 different mechanics. Just had lower control arm swapped 2 days ago but the sound is still there. The mechanics are hearing the squeak but I don't think they're hearing the rubbing/crunching sound because it doesn't happen with every bump. Will be returning today but hoping to get a hint of what it might be. Google gives me a bunch of results about "clunking" noise but my car is not clunking. My car is crunching, and it makes the noise when I go over some speed bumps at a certain speed or if I enter a steep parking lot entrance opening. it occurs only on the right (passenger)s It's like a crunch or a burp or like a harsh rubbing of rubber
I've replaced:
​​​​​*Rear shocks/struts (Monroe) on both sides
*Llower control arm for the passenger side but not for the driver side yet
​​​​​​& 1 or 2 other things were swapped but I can't remember them it was a while ago
Old Jan 21, 2020
mac25's Avatar
Dr Krieger of Modification
Re: Rear suspension making crunching noise
Not much left down there.
-do the tie rods have bushings? Cant remember
-do you have rear swaybar? (Sway bushings?)
also check the rear suspension upper bolts, if they tightened them under spring load while jacked up, they could be loose, while the vehicle is on the ground, with greater load.
Old Jan 28, 2021
Harry Hemi's Avatar
Harry Hemi is an unknown quantity at this point
I have the same crunching noise in my passenger side rear, when turning up an incline.
I relubed all the bushings, doesnt make the noise when I bounce the shocks, but I havent replaced the sway bar end links.
They dont have lube nipples, so oh well. I might have to replace them.
11CoupeEX
Suspension
Mar 23, 2025 01:23 PM
civic0918
Mar 16, 2010 02:20 PM
lambada
Feb 12, 2009 11:43 PM
davidoff1
Sep 24, 2007 12:43 PM
PrYnCeQT
Sep 7, 2006 11:00 AM
