Weird noise....?
Old Oct 25, 2019
Mattkarpov's Avatar
Mattkarpov is an unknown quantity at this point
Weird noise....?
So I have a 2005 Honda Civic EX. There’s a noise in it that bothers me quite a bit. It’s like a humming/buzzing sound coming from the front of the vehicle and sounds like to the left of the car... when I accelerate, it progressively gets louder and higher in pitch. It continues to hum/buzz when I let go of the throttle, so I don’t think it’s anything to do with the engine or tranny considering the RPMs themselves don’t change the sound... any help...?
Old Oct 25, 2019
GolNat's Avatar
Prelude Owner
Re: Weird noise....?
Some things you can try:
  • Swap tires and see if the noise moves.
  • With front of the car off the ground can you hear the noise by spinning the tire.
  • Pull on the wheel that is making the noise and see if it has any play. Twist the wheel (left arm push forward, right arm pull back)
Wheel bearing could be going bad.
ishmot
Jan 2, 2016 09:53 AM
Cheekyboy1021
Apr 29, 2012 04:17 PM
manster972
Jun 16, 2009 02:36 PM
jerry11
Jul 26, 2007 04:45 PM
ZSKCivic01
Oct 26, 2002 01:06 PM
