Strange vibration at 38 mph, like washboard
Old Jun 24, 2015
Fudman's Avatar
Fudman is an unknown quantity at this point
A while ago, I posted on a strange vibration issue here: https://www.civicforums.com/forums/3...35-40-mph.html It was successfully resolved by replacing the control arm bushings. I am now having similar vibration issues.
Two weeks ago, I had my indy replace a left front spring. He then replaced my belts (due to squealing) and valve cover gasket to following week. Shortly thereafter, this vibration occurred. It is primarily a loud audible sound but can be felt in the steering wheel and pedals. It sounds and feels exactly like you are driving over washboard on a dirt road. It only occurs when driving straight ahead, with you foot on the gas and only at 38-39 mph. It seems to need a bump in the road to start the sound. But as soon as you let off the gas or change speeds, it stops.
My indy rechecked everything and could not isolate the cause of the problem. Since the bushing and CV joints are relatively new, that's not the cause of the issue. It's not really a wheel balance issue as the vibration is fairly loud at a specific speed. It doesn't sound like bearings as it only occurs when driving straight. I am wondering if this vibration is related to the spring replacement.
Any thoughts or ideas would be greatly appreciated.
Old Jun 24, 2015
mikey1's Avatar
Re: Strange vibration at 38 mph, like washboard
post a video.....with sound
Old Jun 24, 2015
Fudman's Avatar
It's near impossible to make a video. The vibration and sound happens infrequently. It only happens at 38-39 mph but doesn't always happen when driving at 38-39 mph.
Old Jun 24, 2015
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
checkall nuts & bolts on a arm
check all motor mounts for wear
rotate front tires to rear to see if it follows a tire
check cv joints & wheel bearings
Old Jun 25, 2015
Fudman's Avatar
Thanx. I am suspecting that it could be the motor mounts too. I will check those out.
Old Jun 26, 2015
Fudman's Avatar
Re: Strange vibration at 38 mph, like washboard - FIXED!
It looks like I have fixed the problem. While searching this forum, I found these threads which discuss a very similar problem:
https://www.civicforums.com/forums/3...-rpm-help.html
https://www.civicforums.com/forums/3...28-40-mph.html
The similarity in symptoms was very close. So I started driving in D2 and could not recreate my vibrations. If I switched to D, the vibrations returned. This eliminated suspension as the culprit and indicated that it had something to do with the RPMs or the tranny. So I changed up my ATF (using Honda ATF) and the symptoms have vanished! I have another 3 qts and will change it up again next week. Keeping my fingers crossed this is a permanent fix.
Thank you for your assistance!!!
Old Feb 1, 2020
PMcCann1's Avatar
PMcCann1 is an unknown quantity at this point
These are symptoms of "Torque Converter Shudder" and can be fixed by doing a tranny fluid drain through the drain bolt and refilled with 2.9 new quarts of Honda Brand ATF from dealer. Shaking stopped after that. Look up the proper way to do it & try it out, it's a cheap fix.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
Munzy
21
Oct 7, 2015 07:48 AM
Wariogamer
Sep 29, 2015 09:49 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
