Alignment or not when removing cars front hub?
Old Apr 14, 2011
DH757's Avatar
DH757 is an unknown quantity at this point
Exclamation Alignment or not when removing cars front hub?
I had my front hub removed today to replace 2 broken wheel studs after they got stripped. Also since an 04 Civic requires the hub to be removed they charged me $100 for labor.
Now my question is, do I need an alignment on my car after that?
I noticed after I drove out that my alignment was off and my car pulled to the right on a straight and level steering wheel.
My last alignment was 3k miles ago, since then i climbed onto a curb and hit a huge pothole!
The alignment shop also once told me that on the drivers side the caster can't be aligned because one of the components is bent. I imagine it's the lower arm? I forgot to ask them. Although when they aligned it, the car didn't pull anymore miraculously!
Should I go for an alignment?
Old Apr 14, 2011
amamdani15's Avatar
amamdani15 will become famous soon enoughamamdani15 will become famous soon enough
Re: Alignment or not when removing cars front hub?
just go back to the shop and act stupid. tell them that they screwed up and now your car wont go straight. try to get them to do a free alignment for you, unless you have bought lifetime alignment or something.
Old Apr 14, 2011
MindBomber's Avatar
Live for the Twisties
Yes, you need an alignment done after removing the front hub, all you suspension components hinge off of it so it affects everything.
Old Apr 14, 2011
BlueEM2's Avatar
Whachya lookin at?
Fix the bent piece and THEN do your alignment. That way you won't be doing it twice.
Old Apr 14, 2011
DH757's Avatar
Question Re: Alignment or not when removing cars front hub?
I called the mechanic about the fix, since he's aligned my car before.
He says they need to replace the knuckle and lower body arm in order to align the caster properly. It's only on the drivers side, passengers side is adjustable.
He told me that it'll cost me about $500-$600 to repair.
Is that a fair price?
I'm willing to pay for the fix but I'm not sure if I'm being ripped off.
Old Apr 14, 2011
the control arm is easy to do yourself - look for DIY around the forum - replace it first - knuckles usually does not get damaged easily (the arm is weaker than the solid metal knuckle - Knuckle holds a lot of the key parts of suspension together, after all)
Last edited by sdaidoji; Apr 14, 2011 at 07:47 PM. Reason: was confusing sentence :D
Old Apr 14, 2011
DH757's Avatar
Anyone know if it's easier to replace it myself at home?
Old Apr 14, 2011
Search engine key words:
replace control arm DIY:
result (among others):
Time elapsed: 1 minute
https://www.civicforums.com/forums/3...ntrol-arm.html
Old Apr 14, 2011
DH757's Avatar
Originally Posted by sdaidoji
the control arm is easy to do yourself - look for DIY around the forum - replace it first - knuckles usually does not get damaged easily (the arm is weaker than the solid metal knuckle (it holds a lot of the key parts of suspension together, after all)
i saw a youtube video, it does look pretty easy. However, looks can be deceiving.
So do you mean that the knuckle holds most of the key parts or is it the arm? Didn't quite understand your sentence sorry.
In order to replace the knuckle I need to remove the hub again right? Although I can't do that at home.
Old Apr 14, 2011
DH757's Avatar
Nice thread, thanks for that!
I'll attempt a change by myself, and take the advice for the tools needed.
Old Apr 14, 2011
Knuckle is the one.
Big chances all you need is the arm. the only "harder" part to do is the ball joint, but the Utube one with the jack and the wrench makes easier - just stay away from anywhere the wrench could fly to, or better make sure the wrench will not go flying . No need to remove the knuckle.
Old Apr 15, 2011
BlueEM2's Avatar
Whachya lookin at?
You can use my ball joint DIY as an example too of how to get the knuckle out of the way. Just remember you don't need to actually remove the knuckle to remove the LCA.
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
GH04si
Apr 15, 2015 08:13 PM
Hrddrvs
Apr 11, 2015 11:22 PM
ImmortalEX
Oct 31, 2001 10:00 PM
