Suspension noise?
Old Feb 5, 2006
Tragedy's Avatar
skate or die
Suspension noise?
Well when I drive it only happens when I take a right turn, and only a small % of the time. I am currently on stock shocks and dropped 1.4-1.5". I am planning on buying new shocks, but I do not think the shocks are the cause of the noise. Does anyone have any ideas on what it might be?
Turn right----"click,....click,click,click,....click" proceed to complete turn, ....no noise.
Turn left ----no noise
Again, this only happens about 2 out of 5 times turning right. What part do I need to replace guys?
Thanks in advance.
Old Feb 6, 2006
GACivic's Avatar
GACivic is an unknown quantity at this point
I'm pretty sure you have the same thing I had when I got mine lowered. Something is binding in your suspension. I took mine to Honda to get it fixed, but they had to fix other things and parts are on back order. When I get mine back and it says what they've fixed I'll tell you.
Old Feb 6, 2006
Tragedy's Avatar
skate or die
Cool thanks bro, I dont mind going to the service dept, b/c I have to take my car to honda anyways to fix the broken actuator in my door.
Anyone else?
Old Feb 7, 2006
burke420's Avatar
The World Is Yours!
do you think the rear fender may be hitting on the tires, bc i just got mine aligned last night, and today it was scrubbing, so i took a bar to bend it up. now it did like once, but the noise is nothing near as bad. but when i get home from ill try it better some more on both sides. it was only happening on my left rear, since i got hit htere a while back, and the fender bent down some.
EdGasket
40
Nov 27, 2015 11:11 AM
Strycker
Aug 2, 2015 08:40 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
17
Jul 23, 2015 11:48 PM
mokkush
Jul 14, 2015 04:05 PM
