Brakes Post Your questions about brakes here!
Rear Brakes Quick Help ?
Old Nov 27, 2017
mikey1's Avatar
doing my rear brakes today,
im not quite understanding the adjustment bar that goes between the two shoes....it can screw in and out....what position should this be set at after i have everything installed??
Old Nov 27, 2017
Colin42's Avatar
Re: Rear Brakes Quick Help ?
loose enough for the the drum to slide on with a minimal amount of force, not too tight so the drum wont go on and not too loose where no effort is needed to put the drum on. try to make both sides as even as possible
Old Nov 27, 2017
mikey1's Avatar
thanks....does this adjustment move itself as the brakes wear? or is it a permanent setting?
just by looking at it, it seems like it mostly has something to do with the parking/e-brake?
Old Nov 27, 2017
Colin42's Avatar
it's supposed to self adjust, you can help it by going in reverse at a decent clip and applying the brakes firmly, repeat 3 or 4 times.
Old Nov 27, 2017
mikey1's Avatar
why reverse?
Old Nov 27, 2017
Colin42's Avatar
that way the rear brakes are actually doing most of the work to stop the car, when you're going forwards the rear brakes only do like 20% of the work to stop the car
Old Nov 27, 2017
mikey1's Avatar
so its better to leave it adjusted a bit too loose rather then too tight, and it will snug itself up on its own?
Old Nov 27, 2017
Colin42's Avatar
Personally i would err to the looser side and then do the reverse braking thing. If you check youtube i think eric the car guy has a pretty good drum brake video, it might even be on a honda
Old Nov 27, 2017
mikey1's Avatar
thanks.....thats what i was thinking too
have done a crap load of disc brake jobs over the years, can whip those off in 30 mins to an hour, but its probably been about 20 years since i did drums, needed a bit of a refresher
Old Nov 27, 2017
Colin42's Avatar
Haha i know the feeling, took the rear brakes apart on my girlfriend's car to replace the parking brake cables and it had been about 10 years since i took apart drums.
Old Nov 28, 2017
mikey1's Avatar
one more question.......
when i removed the old shoes, the rubber seal around one of the pistons came off and a bit of brake fluid came out, i put the seal back in place no problem,
does that mean that brake needs to be bled now?
or should it be okay?
Old Nov 28, 2017
Colin42's Avatar
you could try bleeding but i think that might actually be seepage from the wheel cylinder.
random google image:
the black rubber boot is what popped off?
its just a dust shield to prevent stuff from messing up the actual seal. Might want to check the other wheel cylinder and see how its doing. are they original? may be time to replace those as well
Old Nov 28, 2017
mikey1's Avatar
yeah the black boot came off that seals around the piston, there are two of them but only one came off, a bit of fluid leaked out, and i popped it back on
Old Nov 28, 2017
Slumpertcivic's Avatar
Only concern is how long it took for that fluid to weep into that void. Was it a decade or a week?
Consider pulling back that boot in a few weeks and seeing if more has fluid built up. If it does then replace / rebuild the caliper.
Old Nov 28, 2017
mikey1's Avatar
this is the first time the rear brakes have been serviced....so it took 12 years....im the original owner
Old Nov 28, 2017
Colin42's Avatar
I'd still check the boots in a couple weeks to see if there's any fluid. It may have only started leaking recently
Old Nov 28, 2017
mikey1's Avatar
just took it around the block, pedal is a bit spongy
you think it will firm up over a bit of time?
i really dont feel like bleeding brakes in this weather
Old Nov 28, 2017
Colin42's Avatar
How loose were the shoes?
Try the reverse trick yet? it may help
Or you may be stuck bleeding, the hand vacuum pump makes it way quicker
Old Nov 28, 2017
mikey1's Avatar
i went with too loose rather then too tight,
i guess i will give it a few days and see,
my wife mainly drives this car, thats the problem, you can't explain to a woman why the pedal might be soft for a day or two
Old Nov 28, 2017
Colin42's Avatar
Haha, yep.
I have a 2 x 4 holding up a window in the girlfriend's car until the regulator shows up. That took some explaining, and now I'm driving the car until I fix it.
Old Nov 28, 2017
I think i messed up when i opened the rear brakes and it was spongy for some days, but it went back. But since wife, I would bleed if not OK after two days? (hope nothing happens during that time...)
Old Nov 28, 2017
mikey1's Avatar
so yours went back to normal after a few days of driving?
Old Nov 28, 2017
yep, not sure what the issue was, though...
Old Nov 29, 2017
mikey1's Avatar
Ugh...looks like im going to have to bleed this,
havn't bled brakes in years...any suggestions on a "one man" bleeding tool/kit to make things easier?
im old school and used to do it the standard way,
also, is generic brake fluid okay?
im concerned the bleeder valve will be seized and snap off after all these years
Old Nov 29, 2017
Colin42's Avatar
i just use generic dot 3 brake fluid, i bought the vacuum pump/one man bleeder from canadian tire. Line wrenches and penetrating fluid are a good idea as well.
As for the bleeder you could be right, soaking it in penetrating fluid for a couple days before you try to open it. You can bleed at the fitting as well, its not ideal but it can work. Or starting the work when the parts stores are still open is also a good idea.
Old Nov 29, 2017
I would suggest replacing as much of that 12yr old brake fluid as you can.
If you have loosened up the bleeder, might as well pump 1/2 small bottle of fluid per wheel to replace the old.
Old Nov 29, 2017
mine is the pump type, paired with speed bleeders
