Idle Issues If you have idle issues, post here!
Rough idle, keeps dying
Old Dec 4, 2024
RhythmMelody's Avatar
RhythmMelody is an unknown quantity at this point
Unhappy Poor Idle and Turning off
Hey, I have a 2005 honda civic, prior to the issue I was driving the whole day with no problems, I get to a red light and the car turns off and doesnt start. Putting foot on throttle the car started up but letting go of throttle killed it again. After that I could not get the car to start unless throttle was open.
I changed the IACV, spark plugs, air filter housing as i noticed some vacuum leaks with a smoke machine near the throttle, other than that I dont think I saw any other vacuum leaks. I have done a compression test and its 150-160 throughout. Exhaust emissions smell way worst than before but it isnt coolant smoke. Its almost like sputtering, if i hold throttle and let it fight, it eventually idles at lower than 500rpm. Sometimes it dies again after being warm enough.
I took out the O2 sensor and cleaned it out with a cleaner. No codes on the car except misfires now. Any suggestions would be great. I have a video up as well.
(i dont believe its blue smoke, i did have the flash on)
Old Dec 4, 2024
betdriver01's Avatar
betdriver01 is an unknown quantity at this point
Re: Poor Idle and Turning off
if you have misfiring, could be also a fuel problem. did you check fuel pump and filter?
Old Dec 5, 2024
I havent checked the fuel filter, i actually cannot figure out if this model civic has one acccessible. I will be doing a fuel pressure test to see if that shows less than it should.
Old Dec 10, 2024
it is with the pump inside gas tank
Old Dec 10, 2024
yea, you got it bro. i didnt know either till i watched a youtube video about it. also in the process, check o-ring seals and a switch mounted in it.
Old Dec 12, 2024
I have an 05 Honda civic, I'm not sure where my previous post went, so I'm sorry for double posting.
I replaced spark plugs, ignition coils, pressure tester cylinders is 160+ on all 4, I cleaned the throttle, I changed the iacv, I just did timing because I had a water pump leaking so I replaced those two, (car shut off before any of this was changed) o2 sensor was cleaned, fuel pressure is 40+ while priming and 40+ while cranking. Honestly I don't know what to do at this point, air intake was replaced. I'm losing it lol
Thanks
Old Dec 27, 2024
Re: Rough idle, keeps dying
same here bro and no one answer to help us
Old Dec 27, 2024
Yeah brother, nothing to do, I took off my air intake manifold and didn't see carbon build up my last guess was the cat. I suggest you change that
Old Dec 27, 2024
how much we are talking about?
Old Dec 28, 2024
Colin42's Avatar
Aftermarket iac? They're typically junk
Old Dec 28, 2024
Someone here said it's better get one from a junkyard.
24lutzs
Idle Issues
May 13, 2022 03:42 PM
Bronsonj93
Jan 27, 2020 08:05 AM
Dnxracer
Oct 2, 2017 09:13 PM
Mbtech
Nov 8, 2016 09:24 AM
firstforme
Jul 16, 2010 11:33 AM
